D9 convert from torque converter to direct drive
Thank you received: 30
1 day 22 hours ago #259504
by clayton
Well made the mistake of going and looking at a D9 19A and I can’t justify getting it other than I want it! I’m looking to replace the torque converter to direct drive wondering if anyone has a parts machine D9 18A, I need from the flywheel back to transmission or last resort a good used torque converter for a 19A but would much rather make it direct drive, wondering if anyone on here has done this and what problems they had found thank you for any assistance.
Fat Dan
Thank you received: 116
1 day 5 hours ago #259512
by PhilC
I don't know about the D9's but I think the D8 torque convertor drive has a longer chassis compared to the direct drive.
Thank you received: 122
1 day 21 minutes ago #259514
by brian18a
The case and engine frame assembly according to parts book and NPR are different for 18A and 19A. No clue what specific differences are. If 19A is longer would not be impossible to convert, would need longer drive shaft from clutch to transmission. Unless there is something that would make oil clutch interfere with something in frame design.
Thank you received: 629
23 hours 33 minutes ago #259515
Hi Clayton, if it worked out, would this tractor have a clutch and a 3-speed powershift? Reason I ask is that the D8LSA is almost that. It has an hydraulically-operated two-speed clutch (direct and underdrive) coupled to the 3-speed powershift, giving it 6 speeds forward and reverse. The other thing is that if you did manage to build it, that would give an option to other 19As that need unavailable torque convertor parts (I don't know if parts are available, but if they aren't, this would be a potential lifeline for those tractors)
20 hours 32 minutes ago #259517
by brian18a
No it would have a manual oil clutch and a gear drive manual transmission. Very much like 14A and 36A D8s.
18 hours 56 minutes ago #259519
by clayton
Hi Neil yes Brian18a is correct it would not have any sort of power shift to it. The under carriage is in great shape actually the entire machine is in great shape except for the torque converter being bad .
Thank you received: 139
9 hours 5 minutes ago #259524
by Wombat
Not sure what you want to do with the tractor, if you replaced the converter/clutch assembly with an oil clutch, you then have a 3 speed direct drive with a first gear slightly faster than 4th gear in a direct drive 18A.
Wombat
Time to create page: 0.156 seconds
