- Thank you received: 7
Will do. I'll report back once I have the results.Just for fun run the motor up to where the popping is most noticeable and crack each fuel line at the pump .
You should find the one that is missing that would be the one that quits popping and don't miss worse.
Pull the turbo drain line and check for obstructions to oil flow.
Bob
Hi Bob, I cracked the fuel lines today and it stopped popping when I cracked the fuel line for cylinder 3. I still haven't replaced that fuel line yet and I haven't checked valve adjustment yet. What should I check next? Also, can you please inform me where the plug is for inserting the TDC tool? I looked around today and couldn't find it. Is it near the starter?Just for fun run the motor up to where the popping is most noticeable and crack each fuel line at the pump .
Bob
Thanks, I'll keep looking for the plug. Interestingly, the popping completely went away when I cracked open the fuel line on cylinder 3. I tightened it again and the popping came back. I cracked again and it completely went away. I did this 3 times to be sure. The pop seems to be on the exhaust side. This is where I hear it and notice a puff of white smoke when it happens.The plug should be either above or below the starter or on the other side below the oil filler.tube.
When you opened the fuel line could you still hear a lighter pop or chuff.
Can you tell if the pop is on the intake or exhaust side.
Bob
Hi Bob, I'm going to have some time to keep working on the 977 tomorrow. What would you suggest I check next?The plug should be either above or below the starter or on the other side below the oil filler.tube.
Bob
I have replaced all injector nozzles with new ones and the popping\backfiring still persists. I will swap the one in #3 around just to double check.If it is easy to do swap injector 3 for one in another cylinder then check it the issue stays with cylinder 3 or moves with the injector. Process of elimination without conducting major surgery on the motor. Good luck.
cat@acmoc.org
- Chris R
- Jason N
