Track roller grease ?
Thank you received: 84
11 months 4 weeks ago #252809
by mog5858
not sure if this is a good number any more. shell S2 V220-00 GADUS.
side note I thought the corn header grease was made to work with red brass or bronze type parts with specials additives . white lithium grease is not corn header grease but I am sure you could use might be expansive.
11 months 4 weeks ago #252810
by Paul L.
I work at an AGCO dealer and are corn head grease is 00 it is not white lithium, I been using it on my track rollers for quite a few years now.
Thank you received: 788
11 months 4 weeks ago - 11 months 4 weeks ago #252814
your right its green, it is a lithium base grease.
caltex also have what they call epc grease which is lithium based sulphur/phosphorous fortified grease in grades ooo to 3 mind you my data book is a few yrs old
also being in aus what is available here might not be else where or often has different names.
11 months 4 weeks ago #252815
have to be careful mike that that you dont pop the seals using a normal grease gun. that is the idea of using the volume pump is it doesnt generate much pressure so your less likely to pop the seals on track rollers
Thank you received: 64
Thank you received: 405
11 months 3 weeks ago #252900
by D4Jim
Holy crap!! That is cheaper than the Texaco 00 I bought about 12 years ago,. I see it is probably made in Singapore but might be OK. If I needed some 00 I would sure try it.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
11 months 3 weeks ago #252905
by Mike Hudson
Hey 31bill. Excellent grease. Are you suggesting use the tube to apply it with? To prevent blowing seals as was mentioned. All I know to do is use the grease gun lightly
11 months 3 weeks ago #252907
by 3J1Bill
Mike, I use a old CAT factory volume pump that has a built in pressure valve. If I use a regular hand grease pump, I stop when I feel back pressure. Bill
Thank you received: 68
11 months 3 weeks ago #252909
by d4angelo
3J1Bill wrote about buying from Walmart. I just purchased a pair of heavy plastic oil change ramps from them. Ordered on Monday at 5:00 and arrived on Tuesday at 10:00AM. Free Delivery! Yes Free! The next day I ordered 2 one gallon jugs of Shell Rotella straight 30 wt. oil. Arrived the next day................. Free delivery!
Thank you received: 108
11 months 2 weeks ago #252940
by GrantJ
I ordered a bucket of grease last night. I looked for the 30 weight motor oil but only found 15-40. I have used 15-40 in many engines, both gas and diesel and will probably order 5 gallons of the 15-40 oil.
Thank You to 3J1Bill for the good tip. Grant.
