Thirty Five Worth Restoring?
Thank you received: 29
1 year 2 months ago #250882
by Dieselholic92
I recently picked up this Thirty Five gas, and I'm torn on what to do with it. I actually bought it last year, but just got around to getting it now. I'm curious what the general consensus of the group is. If I do restore it, I would be removing the dozer. If anyone is interested in that, let me know. The blade itself is in very nice shape. Nice face, cutting edge, and frog. I was told the engine was rebuilt, but haven't dug into it to confirm. Nothing has been touched on the undercarriage, transmission, finals, etc. I'm not sure what is going on with the idlers, and if that puts the project in the "not worth fixing" category. The rest of the undercarriage looks to be in ok shape.
Thank you received: 321
1 year 2 months ago #250888
by Ray54
My question is what else used the same track. I know the 35 grew into the 40 and then the RD6, and a lot of D6 parts can be used on a 35. But I have the idea in my head the Cat 35 had the same track as a Cat 30, but completely sure on that. But ether way as Cat 30's and Cat 40's and Rd6's give you more of a chance find the idler parts than just looking for another 35.
1 year 2 months ago #250889
by Dieselholic92
Well I do have an RD6 that needs an undercarriage, but just eyeballing it, this stuff seems too small. I haven't done any actual measuring. Maybe I will look around for parts and see what I can find for it. I've been going back and forth on it, so just looking for some reinforcement
Thank you received: 124
1 year 2 months ago #250890
by side-seat
Some interesting engineering on how somebody went in to repair the front idler bushings. I guess it was easier to just cut it and bolt it back together rather than breaking tracks and pulling the recoil assembly.
Thank you received: 502
1 year 2 months ago #250892
by ctsnowfighter
Cable Dozer - could this have caused the front idler problems?
I would wonder about the impact of a dozer blade dropping - lot of force on the equalizer spring and track frame, front idler was not intended to take that impact.
Thirty will accept Thirty-Five Track, I would not expect idlers or rollers to be the same though.
It would appear someone attempted to weld those broken castings, maybe with some of the better materials today, it could be done. Maybe even machine some "fishplates".
1 year 2 months ago #250893
by ctsnowfighter
Thank you received: 928
1 year 2 months ago #250896
by Deas Plant.
Hi, Dieselholic92.
Thanks for the photos. Much appreciated.
That rig looks a bit like a partially assembled IKEA kit. The dozer blade would certainly help to explain the damage to the front idler brackets but, if you restored it as dozer, it would be pretty well assured of being an 'only one known' at most shows.
Thank you received: 6
1 year 2 months ago - 1 year 2 months ago #250901
by cojhl2
Front Idler: Why does that have to be tied down anyway? Maybe put a restriction on it so it cannot get out pf the channel.
I plowed one Fall for a farmer who had a 35. His foreman sent me up the road with it to get in the field and put it to work. Not too long later the owner came up told me to put it back in the shed and put me back on the D4. What a letdown.
9U(2), 5J, IHC544, Ford860
Last edit: 1 year 2 months ago by
cojhl2.
Thank you received: 788
1 year 2 months ago #250903
its certainly had a hard life. they might have been cut with a torch and poorly welded back in to get to a bushing. well some one started to do it up.
Time to create page: 0.222 seconds
