Thirty Five Worth Restoring?
Showing 1 to 10 of 10 results
Dieselholic92
Thank you received: 15
I recently picked up this Thirty Five gas, and I'm torn on what to do with it. I actually bought it last year, but just got around to getting it now. I'm curious what the general consensus of the group is. If I do restore it, I would be removing the dozer. If anyone is interested in that, let me know. The blade itself is in very nice shape. Nice face, cutting edge, and frog. I was told the engine was rebuilt, but haven't dug into it to confirm. Nothing has been touched on the undercarriage, transmission, finals, etc. I'm not sure what is going on with the idlers, and if that puts the project in the "not worth fixing" category. The rest of the undercarriage looks to be in ok shape.
  [attachment=73532]IMG_8890.jpeg[/attachment][attachment=73533]IMG_8884.jpeg[/attachment][attachment=73534]IMG_8887.jpeg[/attachment][attachment=73535]IMG_8895.jpeg[/attachment][attachment=73536]IMG_8898.jpeg[/attachment][attachment=73537]IMG_8894.jpeg[/attachment][attachment=73538]IMG_8888.jpeg[/attachment][attachment=73539]IMG_8882.jpeg[/attachment][attachment=73540]IMG_8892.jpeg[/attachment][attachment=73541]IMG_8896.jpeg[/attachment]
David Gruhot
D & G Excavating, Inc.
Wed, Aug 30, 2023 10:58 PM
Dieselholic92
The rest of the pictures.
  [attachment=73542]IMG_8878.jpeg[/attachment][attachment=73543]IMG_8879.jpeg[/attachment][attachment=73544]IMG_8877.jpeg[/attachment][attachment=73545]IMG_8880.jpeg[/attachment][attachment=73546]IMG_8875.jpeg[/attachment][attachment=73547]IMG_8899.jpeg[/attachment][attachment=73548]IMG_8901.jpeg[/attachment][attachment=73549]IMG_8905.jpeg[/attachment][attachment=73550]IMG_8903.jpeg[/attachment][attachment=73551]IMG_8886.jpeg[/attachment]
David Gruhot
Wed, Aug 30, 2023 11:00 PM
Thank you received: 59
Reply to Dieselholic92:
My question is what else used the same track. I know the 35 grew into the 40 and then the RD6, and a lot of D6 parts can be used on a 35. But I have the idea in my head the Cat 35 had the same track as a Cat 30, but completely sure on that. But ether way as Cat 30's and Cat 40's and Rd6's give you more of a chance find the idler parts than just looking for another 35.
Thu, Aug 31, 2023 2:35 AM
Dieselholic92
Reply to Ray54:
[quote="Ray54 post=250888 userid=2055"]My question is what else used the same track. I know the 35 grew into the 40 and then the RD6, and a lot of D6 parts can be used on a 35. But I have the idea in my head the Cat 35 had the same track as a Cat 30, but completely sure on that. But ether way as Cat 30's and Cat 40's and Rd6's give you more of a chance find the idler parts than just looking for another 35.
 [/quote]
Well I do have an RD6 that needs an undercarriage, but just eyeballing it, this stuff seems too small. I haven't done any actual measuring. Maybe I will look around for parts and see what I can find for it. I've been going back and forth on it, so just looking for some reinforcement
David Gruhot
Thu, Aug 31, 2023 2:53 AM
side-seat
 [/quote]
Some interesting engineering on how somebody went in to repair the front idler bushings. I guess it was easier to just cut it and bolt it back together rather than breaking tracks and pulling the recoil assembly.
Thu, Aug 31, 2023 3:35 AM
Thank you received: 201
Reply to side-seat:
Cable Dozer - could this have caused the front idler problems?
I would wonder about the impact of a dozer blade dropping - lot of force on the equalizer spring and track frame, front idler was not intended to take that impact.
Thirty will accept Thirty-Five Track, I would not expect idlers or rollers to be the same though.
It would appear someone attempted to weld those broken castings, maybe with some of the better materials today, it could be done. Maybe even machine some "fishplates".
Thu, Aug 31, 2023 4:44 AM
Reply to side-seat:
Thank you received: 130
Reply to ctsnowfighter:
Hi, Dieselholic92.
Thanks for the photos. Much appreciated.
That rig looks a bit like a partially assembled IKEA kit. The dozer blade would certainly help to explain the damage to the front idler brackets but, if you restored it as dozer, it would be pretty well assured of being an 'only one known' at most shows.
Thu, Aug 31, 2023 5:21 AM
cojhl2
Hi, Dieselholic92.
Front Idler: Why does that have to be tied down anyway? Maybe put a restriction on it so it cannot get out pf the channel.
I plowed one Fall for a farmer who had a 35. His foreman sent me up the road with it to get in the field and put it to work. Not too long later the owner came up told me to put it back in the shed and put me back on the D4. What a letdown.
Thu, Aug 31, 2023 6:36 AM
Thank you received: 54
Hi, Dieselholic92.
its certainly had a hard life. they might have been cut with a torch and poorly welded back in to get to a bushing. well some one started to do it up.
Thu, Aug 31, 2023 6:46 AM
naylorbros
Thank you received: 25
Reply to trainzkid88:
The track chains will fit the S/PS Thirty, L/PL Twenty, Thirty Fives Diesel and gas, Twenty Five, Twenty Eight, R3 and maybe a couple of others with a few links removed here or there. The undercarriage will move up to the Forties or the RD6/D6 tractors. I have one good front idler yoke left and two ok front idlers left. I do not know if I would take that project on.
THanks
Ken
Thu, Aug 31, 2023 9:23 PM
| Kingaroy, Queensland
