- Thank you received: 0
Hi, swilling.
There were 2 series of the Cat 22, 2F from 1 to 9999 and 1J from 1 to 5,000 something. That would make your machine a very early first series which, I think would place it somewhere in 1933. If I am wrong, I have ABSOLUTELY no doubt that someone will be along to correct me.
As Dandy Dave said, if you can find a parts machine with at least most of the parts that you need, that would be a good place to start, especially as it would likely leave you with bunch more parts for future 'emergencies'.
The 22s were among the most bullet proof small crawlers of that era.
Just my 02.
Congratulations! You're very enthusiastic which is a great ingredient to have. No doubt you will get it running - these are very simple, basic machines. A parts machine as mentioned is a good way to go but if you find space at a premium, there are plenty of sources for Twenty-Two parts. As well as locating the parts that you're missing, having the parts catalog is very useful because the drawings are to scale and accurate, meaning you can see how the parts are laid out/assembled. Some parts are not only common within the 2F / 1J series but even to other Cat tractor models so do ask if you're in doubt. Draining and replacing fluids is a good idea, as is refurbishing the two key ingredients to easy starting / good running - the carburettor and the magneto. Get them in good shape and you'll be happy. Steering can be the biggest challenge since if a clutch is stuck and you can't use the bush methods to unstick it, diassembly is required. Please post lots of photos as you bring it back to running condition.
Welcome, and congratulations on the first of many Caterpillar tractors!
You are fortunate that the spark plug cover is still on it, usually it gets tossed or lost first. You have the hot rod belief: It turns, it burns!
Myself, I would clean things up and see what needs to be loosened up besides the billfold for parts purchases
Hopefully it steers still, if not, that is a chore to get steering clutches unstuck, etc.
The 22 was the Model T of Caterpillars. A LOT of them built, and surprisingly, many floating about in various conditions for sale.
Yours although missing a few parts, looks pretty good from here.
Hmmm, NorCal ehh? Maybe someone will chime in and offer to help? I am in Yuba City, but my hands on experience for a 22 is very limited.
Keep on sharing progress reports and pictures of course, this is exciting for many of us as well! JuiceMan.
Looks to be a nice machine. Seems to have a PTO judging by the lever. There are actually an amazing amount of small changes over the years that these were made, but most of them dont make much difference. Much of the driveline parts are also the same as a 15. I also have a couple of low serial number 22s and one thing that had me puzzled was the flywheel and clutch. On #811 and older they are different than the later ones. It turns out that the early 22s also used a 15 flywheel and clutch.
The first thing that I would do is to get a friend and put the machine in gear and have the friend turn the crank. Push the clutch down and see if the engine still turns. If it turns, the main clutch is not stuck. Then with the trans still in gear , pull both steering clutches back and see if the engine can be turned. If YES, your steering clutches are free,
I dont know if the radiator core would be the same as a 15 or not. I will try to compare my 22 parts book with my 15 book today. The sparkplug cover is from a later machine. The very early 22s had an unvented sparkplug cover was changed to a vented one at some point. Probably made the plugs run too hot. There was a good thread recently about 22 parts compatibility with the {rare} small 20. It is an interesting thread.
Hey "Juiceman", you need a tailseat 22 in your stable !!!!!
great info, thanks! learning alot already. I appreciate you. Yes it also does have a PTO, I assumed that was standard on all of these but I guess not.
heres the pto
support@acmoc.org
- Chris R
- Jason N
