D7 3t steering Brake
Thank you received: 64
1 year 7 months ago - 1 year 7 months ago #249329
by V14
Making another thread just to make them easier to search for in the future. I dug into my right steering brake issue today. Removed the floor and got that spring out which I thought was the issue. That of course didn't fix my problem since nothing is ever simple for me. Photo attached of the spring they had in there before compared to the proper part.
Now that it is in i can push the brake in a bit easier but it still won't return. Im sure they had the huge spring in there to alleviate that issue before but now fails. The pedal does depress about 3/4 of the way as the manual states (same distance as the other) so i do not think i need to adjust number 2 adjusting nut in the second photo. I believe number 9 support screw needs backed out a turn and a half but i cant seem to find it. Neither the servicemens reference book nor operating manual are clear as to where it is.
I'm also considering that isn't even the problem and it may be the length on rod 3 but trying to turn that bolt was not going well so i shut it down for the night and figured id ask the experts once again. Appreciate any input you guys put forth.
Last edit: 1 year 7 months ago by
V14.
Thank you received: 946
1 year 7 months ago - 1 year 7 months ago #249332
by Deas Plant.
Hi, BVAL.
Unless I am much mistaken, the support screw, 9, is under the steering clutch/brake housing and is accessed from under the machine. That being the case, there is always the possibility that some previous encounter with Mother Earth has broken it off.
Deas Plant.. Reason: add info.
Thank you received: 83
1 year 7 months ago #249339
by V14
I guess that is possible, I did open that housing and looked but did not see it. I'll check again later today while I continue cleaning all the built up dirt crud out from under the floor area. The more I think about it though it doesn't seem like that would prevent spring back just difficulty pushing in but I've only messed with standard drum/disk brakes on vehicles.
1 year 7 months ago #249340
by V14
Gemdozer, I typed that horribly above should state it does move 3 3/4 as the manual states not sure what I was thinking when I typed that up.
1 year 7 months ago #249343
by gemdozer
The stering cluch adjustement rod is in rear side housing near the brake bolt adjustement and you have to loosed the jam nut and turned the big nut right side for adjusted or left side for desajusted
1 year 7 months ago #249346
by gemdozer
No the number 2 is the brake nut adjustement the big nut is bolted to the top yoke and shaft from hydrolic control boster
1 year 7 months ago #249347
by V14
Grabbed my service manual and see what you are talking about. Did not think I would need to mess with the steering clutch unless I needed to replace drums.
Thank you received: 341
1 year 7 months ago #249349
by Ray54
Number 2 is the brake adjustment. The support screw is under the tractor sticking out of the case, has small curved piece welded to case to protect the screw and lock nut. The steering clutch adjustment is no shown in diagram posted. It is a large nut(I want to say 1 5/8 inch head but large none the less) with cone shape on the bottom with a lock nut. DO NOT ADJUST THE DIFFERENT ROD GOING INTO THE BOOSTER until you have the other things correct. And most likely you never adjust those unless the uneducated have already been there.
