1956 D6 9U rescued.
1956 D6 9U rescued.
Thank you received: 74
1 year 1 month ago #249770
by dpendzic
Dave---the parts machine i have is a 1956---9U-23367
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Thank you received: 71
1 year 1 month ago #249786
by Dandy Dave
The part numbers are the same in the parts book. I have them coming in the mail now as I would like to get this thing moving. I'll keep that in mind for anything else that this old D6 might need.
1940 Cat 12 Grader 6M17
1956 Cat D2-5U
1956 Cat D6- 9U 23721
Copake, NY.
1 year 1 month ago #249878
by Dandy Dave
Does anyone know if the new steering clutch lever handles from Cat are like the original's? Part # L829. I see aftermarket ones on the internet but they are all plastic and don't seem to have the steel nut to tighten them
1956 Cat D2-5U
Copake, NY.
Thank you received: 34
1 year 1 month ago #249898
by Busso20
Dandy Dave, order from cat dealer, the extended number is 0L 0829 to be able to find on new sis system, yes you can get them same as originals, it could be either O for orange or 0 as a number at the front.
1 year 1 month ago - 1 year 1 month ago #249909
by Dandy Dave
Ran it through my local Cat website and it worked. These are now in the mail with some other stuff. Many thanks.
1956 Cat D2-5U
Copake, NY.
Busso20
Thank you received: 775
1 year 1 month ago #249931
by Dandy Dave
Factory Cat canopy.
I think so. Does anyone have measurements or some sort of print so I can rebuild it correctly?
1956 Cat D2-5U
Copake, NY.
1 year 1 month ago #250254
by Dandy Dave
Moving along with the D6 rescue and resurrection. Good pulley's for the water pump installed. Waiting for some gaskets from the Great Yellow Pussy Cat. Pony exhaust found and arrived yesterday. Also a pair of oil cooler lines as the ones on the machine laid in the dirt and rusted through. 4 New handles arrived for the steering and master clutch and blade control. Two new knobs for the trans levers. Still waiting for one. Also pressure washed it off on the lower end, and front. Removed the front half of the hydraulic tank to free up the stuck spool valve and reinstalled. New belts installed on the pony motor. When a few more gaskets arrive I will be able to start it up and get the wheel barrels full of dirt out from under it.
1956 Cat D2-5U
Copake, NY.
Thank you received: 999
1956 D6 9U rescued.
Time to create page: 0.211 seconds
