D4 7U main clutch. 49-50?
1 year 7 months ago #247465 by gwoods
Replied by gwoods on topic D4 7U main clutch. 49-50?
I then after looking have the dry clutch, do you have any suggestions as to ways maybe to get clutch to release. I know thanks to all you guys to put dozer gear in neutral. Will I need to take all covering off over clutch and then?
Gary Woods
1 year 7 months ago #247466 by Rome K/G
Replied by Rome K/G on topic D4 7U main clutch. 49-50?
That "wet" clutch looks dry to me???? lol Damn dry!
1 year 7 months ago #247470 by rax200
Replied by rax200 on topic D4 7U main clutch. 49-50?
Garry,
If you have a close look at the cover you may have a split cover just over the clutch compartment, this is where the serial number comes in if you see 5he attached image it will show you where to find the serial number,
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
1 year 7 months ago - 1 year 7 months ago #247475 by trainzkid88
if its a dry type the is a small rectaglish cover over the clutch compartment. if you remove that you can get acess to adjust the clutch and give the throwout mechanisim a squirt of penertrating oil. only oil the mechanisim dont get it on the clutch plate itself.
i would also replace the wick in the oil cup you should be able to get some from any good industrial or bearing supplier. abit of google search found a listing with mcmaster-carr for wool felt wicks in a few different shapes and sizes and grades.
you can also make your own with some pure worsted wool (raid nanna's knittin basket. make sure its pure wool) and some fine copper wire wrapped in a spiral to give it some support it doesnt need to be very long it only has to carry oil into the pipe which then drips into the funnel that then lubes the yoke assembly. most of the length is in the oil cup not the tube.
the strand off a cotton mop would also work
we always filled the cup and gave small squirt down the tube itself so it always got some oil.
Last edit: 1 year 7 months ago by trainzkid88.
1 year 7 months ago #247518 by gwoods
K, thank you for telling me about wick material ( definitely ) a dry clutch. I had added some 30 wt oil to lower cup without absorption. I will put a new wick in both cups, after that will put add some 10 wt oil. I have removed the access shield above main clutch. I
Gary Woods
1 year 7 months ago #247531 by trainzkid88
pour some kerosene down the oil cup to clean it and check it does flow into that funnel it may be blocked with crud. the oil viscosity grade doest matter much with this as long as its getting some oil.
1 year 7 months ago #247536 by gwoods
Will do on kerosene today, thank you trainzkid88. Continue helping, please.
Gary Woods
1 year 7 months ago #247557 by ol Grump
Replied by ol Grump on topic D4 7U main clutch. 49-50?
I've had several machines that had sticky clutches that wouldn't release when they were cold. I think what happened was the pilot bearing was overgreased and would stick to the flywheel. My cure was to dump a gallon or so of diesel into the housing, work the clutch lever, turn the engine 1/4 of a turn, work the clutch lever some more, turn engine, move movement on the lever, etc. After a bit I could hear the clutch "clunk" as it came loose. Then it was time to drain the diesel, add more and give the clutch a wash per the book. That took care of the problem.
Just something else you might try if you haven't already
The following user(s) said Thank You: bernie
1 year 6 months ago #247736 by gwoods
Thank you very much for information and remedies.
Gary Woods
