D4 7U main clutch. 49-50?
Thank you received: 7
1 year 7 months ago #247429
by gwoods
The is gnwoods, question to old Magnet or all, would you still use 30 wt saw oil in main clutch? The wick in the access to clutch is just soft sponge?? My brake clutches have freed up much blaster and a lot of back and forth pushing and pulling. This has gave me incentive to move on to main clutch.
Gary Woods
Thank you received: 80
1 year 7 months ago #247435
by gwoods
I have looked and found oil rated 10, this would be sae oil? I am OCD when it comes to understanding. I am older than my d4 7u ( 75 ) but have never worked on one. Than you for your help.
Gary Woods
Thank you received: 276
1 year 7 months ago - 1 year 7 months ago #247436
by rax200
This is in the library
You need to provide the serial number of the tractor.
regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 1 year 7 months ago by
rax200.
Thank you received: 186
Thank you received: 788
1 year 7 months ago #247444
ours has the standard type clutch and the oil is to lube the clutch bearing we just used normal engine oil. the wick should be cotton string or similar not sponge.
1 year 7 months ago #247446
by rax200
Hi Josh,
I am with you, that's why I asked for the serial number.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1 year 7 months ago #247454
by gwoods
How do I know the difference between a dry clutch and oil clutch? Down in the belly there is not any oil. Does this make it a dry clutch? All I see is cup on top of the ring and small cup in front of left brake petal. Hand lever to pull will not move. I don’t know what steps need to be followed. I need advice. Thanks
Gary Woods
1 year 7 months ago #247458
by gemdozer
If you have a small cup in front of left brake pedal you machine have a dry master cluch and maybe the collar on cluch shahtis missing lubrification and maybe the interlock is in trouble and make sure the transmission is in neutral fonction
1 year 7 months ago #247464
by rax200
Here ar som photos of a dry clutch and an oil clutch
Dry Clutch
Oil Clutch
as mentioned before we need the Serial number to confirm
regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Time to create page: 0.192 seconds
