How to take water pump apart from D4 7U?
Thank you received: 124
1 year 7 months ago - 1 year 7 months ago #246980
by side-seat
See if my pictures are of any help.
Fan should just pull off after you remove the six bolts. The shaft is straight and has a woodruff key. I showed a safe way to pull with a bar puller so no hammering is necessary. They also sandwich up to the driving hub and hold pulley assembly.
Thank you received: 7
1 year 7 months ago #246981
by gwoods
Thank you for help, another member gave me video of The Pacific Northwest Hillbilly (Matt) taking a 1950 D4 7U water pump apart and followed with reconditioning. I have watched most all of his repair videos. I missed the water pump repair video. I am so glad I became a member Acmoc.
Gary Woods
1 year 7 months ago - 1 year 7 months ago #246982
by side-seat
I just went back and reread your original post.
I sorta missed your question.
You need to remove the broken bolt on the adjuster.
Looking at this one I see that this has a broken bolt. But you may still have a second one like this one.
If you can drill the broken bolt centered, try an easy out.
May take some heat from an acetylene torch.
Since I have a milling machine I can accurately drill it.
If you can’t drill it yourself or mess up the thread you could try drilling it for a 5/16” bolt.
Thank you received: 788
1 year 7 months ago - 1 year 7 months ago #246989
here a tip clean the dirt off it and soak with your favourite brand of possum piss. and the big secret is allow the time for it to soak in re-apply a couple of times too. impatience has broken many things.
a soldering iron can be handy for applying heat to thins like screws and small bolts and being precise with the heat unlike a heating torch.
Time to create page: 0.152 seconds
