D4 7U Track Sprocket
1 year 9 months ago #245812 by M00051
D4 7U Track Sprocket was created by M00051
I have a D4 7U28085 tracks are shot my pads are ok. I purchased a scrap Cat for decent chain, front idlers and lower rollers. What is the easiest way to repair rear sprockets? Is there a way to weld new tooth assemblies on without removing the track frame?
D4-7U
D6-9U
1 year 9 months ago #245813 by neil
Replied by neil on topic D4 7U Track Sprocket
We did exactly that. We cut about a 60 degree sector out of a new sprocket ring, and welded it onto the spokes without having to remove the track frames or sprocket. This was on an HT-4 which is not great for removing track frames. Did it just this past summer to both sprockets. Couldn't be happier with it
1 year 9 months ago #245824 by hfdzl
Replied by hfdzl on topic D4 7U Track Sprocket
Also try here if you want. He makes inserts for the sprocket teeth. www.manta.com/c/mmdjxfq/pigeon-products-mfg.
Does a good job, lots welding. If you are handy you can make your own liner inserts.
Good luck
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
1 year 9 months ago - 1 year 9 months ago #245832 by Rome K/G
Replied by Rome K/G on topic D4 7U Track Sprocket
I dont like welding near bearings or close to an engine, I have seen [not my machines] where bearings were "arc'ed" or pitted from welding on the machine.
Last edit: 1 year 9 months ago by Rome K/G.
1 year 9 months ago #245834 by hfdzl
You have to be careful to welder ground placement.
1 year 9 months ago #245838 by trainzkid88
Replied by trainzkid88 on topic D4 7U Track Sprocket
place the work lead close to the weld and have a spot ground nice and clean for it to get a good contact. it can be a good idea to shift it for each weld many bad welds can happen due to poor prep and crook earth clamps the best are one that are a proper clamp and not just relying on spring pressure. remember electric current will always flow to terra firma by the path of least resistance.
1 year 9 months ago #245845 by dpendzic
Replied by dpendzic on topic D4 7U Track Sprocket
when i welded my new sprocket rims on I moved the ground lead to each spoke as i welded the rim to that spoke
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
1 year 8 months ago - 1 year 8 months ago #245897 by restore49
Replied by restore49 on topic D4 7U Track Sprocket
Not sure proper name - Beam Clamps with a bolted on ground wire and ground clean clamp area work great and easy to move to new spot.
Last edit: 1 year 8 months ago by restore49.
1 year 8 months ago #245942 by M00051
Replied by M00051 on topic D4 7U Track Sprocket
dpendzic, What did you mean by welding sprocket rims on? Is that a part I can purchase if I do remove the track frames? I guess I think I'm looking for the best solution, I just thought maybe there was a ring with bolt holes available to cut old sprocket tooth ring off, weld ring with bolt holes on old sprocket and then bolt tooth sections on? I must be dreaming right! Vic
D4-7U
D6-9U
1 year 8 months ago #245949 by dpendzic
Both Berco and Cat had new sprocket rims==I went with Cat as they were a little cheaper---I don't know if rings with holes are available for these old machines---newer machines have a sprocket with holes to bolt on sections of teeth---as Neil said you can cut a section out of a new rim and slide the rim on and then weld the section back in---the other alternatives is build up the teeth with weld or weld inserts in the old teeth
