D4 equalizer bar
1 year 9 months ago #245300 by Deas Plant.
Replied by Deas Plant. on topic D4 equalizer bar
Hi, Josh.
Quick 'kwesrtyun': will the traxcavator idlers swap over to the recipient machine's idler mounts?
A kew-ree-yuus mind would like to know - maybe several of 'em.
1 year 9 months ago #245306 by josh
Replied by josh on topic D4 equalizer bar
I don't know.
You might be able to do that with the addition of a couple spacers, but one would need to see all the parts side by side to see what fits and if the shafts are the same, there is mention of adapting one of the big idler groups with the addition of 4H2020 arm, but that is not one of the idler groups used on the loaders.
There were lots of different of options and changes over the years on the D4 and loader parts,
putting on a big idler transfers a lot of load onto the front of the track frame, and for at least most of the U series, it calls for heavy duty track frames to be used with big idlers.
1 year 9 months ago #245312 by Deas Plant.
Hi, Josh.
Thank you, Sir. I did not know that there was heavy duty track frame used with the big idlers. Many people seem to have the idea that the big and small ones are interchangeable with the removal or addition of one track link.
1 year 9 months ago #245313 by Jimmy977
Replied by Jimmy977 on topic D4 equalizer bar
Ok thanks for all the information. My machine is very early 7u loader. I don't know if it is big or small idler. I will check.
1 year 9 months ago #245314 by Deas Plant.
Hi, Jimmy 977.
I could be wrong - I dimly remember it happening once - LOL - but I think the loaders all came standard with the big idlers - helped to make them more stable fore-n-aft with a full bucket.
1 year 9 months ago #245318 by d2gary
Replied by d2gary on topic D4 equalizer bar
I took some quick measurements on my 2 machines and the loader track frames are longer by about 7 inches.Center of axle to center of axle is about 4 inches longer.My 7u dozer has the big front idler and it looks like the loader idler is close to the same dimensions.I don't have a 7u book specific to the traxcavator so I can't cross part numbers but it would definitely not be a simple swap.As has been said I don't think you would gain anything from the longer frames or the hard bar on a dozer or ag tractor
The following user(s) said Thank You: kracked1, gauntjoh, Fat Dan
1 year 9 months ago #245320 by Deas Plant.
Hi, d2gary.
You would definitely gain some stability on a dozer with a 5-roller track frame and a big idler and even with a big idler on a 4-roller track frame. That said though, the big idler would not be as much of a blessing on an ag tractor although the 5-roller track frame may well make it a smoother ride.
Again, I don't KNOW but I think the oil pans are the same for the 4-roller and 5-roller tractors with equalizer springs but different for the loader hard bar units. That said though, I would not think it would be all that hard to cut the hard bar mounts off and fabricate the spring mountings on the loader track frames if one was serious about doing the swap.
just my 0.02.
1 year 9 months ago #245324 by Jimmy977
I have a 1957 977, hardbar is bolted on. The D4 loader is 1947, I'm not sure if it is welded or bolted. I will look when I get a chance.
1 year 9 months ago #245326 by Deas Plant.
Hi, Jimmy977.
I think it would be a pretty safe bet that it is bolted - - - - unless someone has done a 'butchershop' repair on it at some time.
just my 0.02.
1 year 9 months ago - 1 year 9 months ago #245641 by Fat Dan
Replied by Fat Dan on topic D4 equalizer bar
I found an equalizer bar in the service manual for D4 ... 6U and 7U
I uploaded the Caterpillar Service Manual for models D4  4G, 2T, 7J, 5T, 6U, 7U to the library
ACMOC Member
Last edit: 1 year 9 months ago by Fat Dan. Reason: Clarity
The following user(s) said Thank You: Shaban1983
Time to create page: 0.209 seconds
