D4 equalizer bar
1 year 9 months ago #245171 by Jimmy977
D4 equalizer bar was created by Jimmy977
Hello folks,  I see Henderson sells equalizer bars, what is different about these compared to running a spring?
1 year 9 months ago - 1 year 9 months ago #245172 by Rome K/G
Replied by Rome K/G on topic D4 equalizer bar
Your tractor will never be Bud Droopy again.
Last edit: 1 year 9 months ago by Rome K/G.
1 year 9 months ago #245175 by Deas Plant.
Replied by Deas Plant. on topic D4 equalizer bar
Hi, Jimmy977.
The equalizer springs went the way of the dinosaurs back in the 1950s and '60s. Since then, solid equalizer bars have been 'the go'. with rubber pads under them.
Hi, ROME K/G.
Unless said equalizer bar breaks - - - in which case there will a SEVERE droop. And I have seen broken equalizer bars in D10s and D11s. Quite a let-down.
1 year 9 months ago #245178 by Jimmy977
Replied by Jimmy977 on topic D4 equalizer bar
Ok thanks.  I have a parts cable operated d4 7u loader, serial number approximately 350. I'm thinking about the 5 roller track roller frame swap to a 7u d4 bulldozer.
1 year 9 months ago #245187 by Deas Plant.
Hi, Jimmy977.
I don't know if they will switch straight over as I think the track frames on the loader would be rigid mounted but they may possibly still have the equalizer spring too. I just don't know.
There may also be an issue with the sway braces on the blade with the longer track frames. Again, I don't know for sure but suggest that you do your homework.
1 year 9 months ago #245189 by kracked1
Replied by kracked1 on topic D4 equalizer bar
The track frames are solid mounted. I do believe there will be clearance issues as Deas has said with the dozer frame.
1 year 9 months ago #245191 by Deas Plant.
Hi, kracked1.
If my memory serves me right, the back end of the track frames are the same, complete with diagonal brace and outer bearing. What I don't know but strongly suspect whether the rigid mounting on the loader track frames is in the same place where the equalizer spring pockets would be. If that is the case, then he would need to cut off the rigid mountings and fabricate the pockets for the equalizer spring - or bar.
1 year 9 months ago #245193 by Jimmy977
I am not sure if it will work. I have read here of folks considering doing this type of swap. I don't own a D4. I have one locally I plan to purchase this spring. So I'm not aware of how spring mounts exactly. I was thinking I could fabricate a mount that bolts on to track frames where the rigid mount attaches. But I was unaware that spring sits in a pocket, so maybe not feasible.
1 year 9 months ago #245194 by Jimmy977
I was also planning on swapping or modifications to c- frame for clearance of longer track frame. I see the old holt manufacturing c-frames look like they have more clearance in front of track frame.
1 year 9 months ago #245195 by GrantJ
Replied by GrantJ on topic D4 equalizer bar
I dont know if the D2 rigid frame is similar to the D4, but on a D2 traxcavater parts machine that I have the oil pan is different than on regular D2 crawler. You might want to check and see if that also applies to a D4. Just a thought. Grant.
