19a d9
2 years 1 month ago #244869 by tmoline
Replied by tmoline on topic 19a d9
no luck there either
2 years 1 month ago #244872 by Deas Plant.
Replied by Deas Plant. on topic 19a d9
Hi, tmoline.
Where are you based? I have a contact here at an auto spares outlet who seems to be able to dig up a fair bit of non-auto stuff - and seems to enjoy doing it.
Quote from PhilC back on page 1:
"That part number is not for the lip seal it is for the entire seal assembly. Do you need the entire seal assembly or just the lip seal? The lip seal is still available part number 5P-2376 which was 5H4894."
Unquote.
Do you need the whole assembly or just the seals - 5P2376?
2 years 1 month ago - 2 years 1 month ago #244873 by Old Magnet
Replied by Old Magnet on topic 19a d9
I vaguely recall edb talking about a carbon seal used on large  (possibly ammonia) refrigeration compressors that worked as a substitute. Sorry, that's all the info I have.
Don't know if this will do any good but I believe the Twin Disc part number for the carbon ring is a #203077
Last edit: 2 years 1 month ago by Old Magnet.
2 years 1 month ago #244878 by PhilC
Replied by PhilC on topic 19a d9
The carbon seal I think is part number 5H4899 Element. Listed as not available on Cat.
These are the same style seal as used on the 15A D8s but obviously bigger.
2 years 1 month ago #244889 by kracked1
Replied by kracked1 on topic 19a d9
My guess is that is a convertor made by Twin Disk for Cat. Just like the ones on the Allis Chalmers tractors. If so that seal is made of unobtainium! The last one popped up for sale on Australian ebay a year ago and lasted 8 minutes. Sold for just under $800! There are alot of tractors clunked in the head because of leaky seals. I found a used convertor for the Allis tractor I was working on last summer. It was a miracle that I found a good used one for a reasonable price! That will be your best bet for your tractor also. Those carbon seals have no repair to them.
2 years 1 month ago #244892 by Old Magnet
Normally a little seal leakage would not be a problem but Cat cheaped out and didn't use the recirculation system,just let the leakage go to ground.
The following user(s) said Thank You: gauntjoh
2 years 1 month ago - 2 years 1 month ago #244898 by Old Magnet
Would need the Twin Disc model number and any other tag specifications.
Appears complete Twin Disc seal service kits may still be available as #X-205161-B
You won't like the price at $700+ each and you will need two of them.
www.machinerytrader.com/parts/search?Par...1-B&SearchType=Start
You could also try here for just the 203077 carbon ring
clutchcointl.com/product/twin-disc/
And yet another possible (bargin) price for the 203077 ring
www.ebay.com/itm/111250321101
2 years 1 month ago #244902 by trainzkid88
Replied by trainzkid88 on topic 19a d9
you could try sealing technologies in brisbane, qld. they custom made a carbon seal for the seawater cooling pump on a mirrlees marine engine i worked on i offsided to the ships engineer that did the job he's a family friend.
you would need the dimensions or a tech drawing of the part for them to copy. and it probably wouldnt be cheap.
2 years 1 month ago #244930 by Deas Plant.
 Hi, tmoline.
Does this look like what you are chasing?
2 years 1 month ago #244934 by Old Magnet
No, that's a rear crankshaft seal for the 3406B/C/E/C15.
