19a d9
1 year 10 months ago #244798 by tmoline
19a d9 was created by tmoline
Anyone out there know where I can get 4 5H4903 seal assy, for the torque convertor
1 year 10 months ago - 1 year 10 months ago #244800 by Deas Plant.
Replied by Deas Plant. on topic 19a d9
Hi, tmoline.
If Cat can't supply - which would surprise me - try a bearing service company as they often stock seals as well. If they are any good, they ought to be able to cross reference the part # - and probably cheaper too.
Last edit: 1 year 10 months ago by Deas Plant..
1 year 10 months ago #244809 by bruce oz
1 year 10 months ago #244812 by Old Magnet
1 year 10 months ago #244814 by Rome K/G
Replied by Rome K/G on topic 19a d9
Conman equip is a joke! Who wants a used seal? they never have what they list either.
1 year 10 months ago - 1 year 10 months ago #244821 by trainzkid88
Replied by trainzkid88 on topic 19a d9
if you google search the part number you can often find the nsn or national stock number as many of these machines where used either by the military or us parks service, forest service or the federal highways dept.
this is helpful with bearings, gears, and oil seals as most of that stuff wasnt bespoke but was off the shelf from companies like hyatt, timken and chicago rawhide.
the nsn can show what other makes and models used those parts. sometimes it will also show updated part numbers and as the dealers dont always have listings in the catalog for the older equipment they can have info if the pn has updated.
Last edit: 1 year 10 months ago by trainzkid88.
1 year 10 months ago - 1 year 10 months ago #244822 by trainzkid88
cat has a listing on parts.cat have you called your local dealer. that seal fits the d9E, 583h pipe layer and the d353c industrial engine.
and yes like deas suggested you can also try a bearing supplies joint sometimes they can crossmatch part numbers. if you have the old seal they can often measure it and match one up. that if you get it out with out completely destroying it. also it might have the manufacturers part number on it. thats often the case with bearings and seals that are off the shelf. and it canbe cheaper as you dont pay for someone to put it in a yellow box or a bag with a fancy sticker.
1 year 10 months ago #244826 by PhilC
Replied by PhilC on topic 19a d9
The listing on parts.cat.com is notated as "Indirect replacement available contact dealer" which seems to be Cats code for "Not available"
That part number is not for the lip seal it is for the entire seal assembly. Do you need the entire seal assembly or just the lip seal? The lip seal is still available part number 5P-2376 which was 5H4894.
According to the manual only two are needed per torque converter.
The following user(s) said Thank You: Deebo
1 year 10 months ago #244866 by tmoline
Replied by tmoline on topic 19a d9
cat can't supply and it is a carbon seal no match up
1 year 10 months ago #244867 by tmoline
tried them
Time to create page: 0.323 seconds
