Recognize this blade?
1 year 11 months ago #243979 by Mschwartz
This blade is on a 78 A D4D. I know it has been heavily modified but is it a Cat blade?  Wondering if the pins that you use when changing the angle might be available as replacement part?  Is it a 4A blade?  Thanks, Mike
1 year 11 months ago - 1 year 11 months ago #243983 by Rome K/G
Replied by Rome K/G on topic Recognize this blade?
Cat blade and C frame but someone has removed the triangle lift arm and pivot.
Should look like this,
Last edit: 1 year 11 months ago by Rome K/G.
1 year 11 months ago #243990 by Deas Plant.
Replied by Deas Plant. on topic Recognize this blade?
Hi, ROME K/G.
I thought the D4D was the first series with the blade lift rams on the hard nose. If I am 'kee-wrecked', the assembly shown in your photo would have been up to D4C.
That said, I do think it is a Cat 4A blade assembly and that they have taken the triangle from an earlier dozer lift arrangement and welded it direct to the C frame to give a lift point for the ram 'coz there was no pivot assembly across the track frame for the D4D.
Mschwartz, if you look around the top right corner of the back of the blade, you may find either the remnants of a tag or where the rivets attaching said tag once were. If the tag is gone and you can find the rivets, there oughta be a serial # stamped into the blade metal.
Please feel free to correct me if I am wrong 'coz I'm no 'ex-spurt'.
1 year 11 months ago #243995 by Old Magnet
Replied by Old Magnet on topic Recognize this blade?
Originally looked like this....
2J0883 pins should still be available,if not I have a couple of spares.
1 year 11 months ago #243996 by Mschwartz
Replied by Mschwartz on topic Recognize this blade?
Thanks. OM, your scan is much cleaner than the one in the library. I had found the 2J883 number but was having no luck. Do all of the old part numbers need a 0 added into them to search? If you had a close up picture of pin and how they were originally secured that would be great. I am thinking there was a smaller keeper pin on a chain to secure the pin? Thanks, Mike
1 year 11 months ago #243997 by Old Magnet
Yes, in most cases you need the four digit number plus prefix.
I'll see if I can find those pins a get a picture later today.
The following user(s) said Thank You: Mschwartz, Fat Dan
1 year 11 months ago #244009 by Old Magnet
As it turn out the pins I have are the 4F1252 units used on D6 & D7 blades.
I'd expect the D4 units to be similar.
1 year 11 months ago #244011 by Rome K/G
"lolliops" lol
1 year 10 months ago #244020 by Mschwartz
Took a few more pics this afternoon when I fed cows. First is the trunnion and linkage like what is supposed to be with the 4A blade, this is on a 7U. Found the rivets on the blade but no tag. I thought that there were no numbers but I think I see some in the picture now. This is what is left of the worn out mess of the pins I am wanting to fix. Thanks, Mike
1 year 10 months ago #244024 by Deas Plant.
Hi, Mschwartz.
Just the two rivets are enough to identify it as a Cat blade but yer right, some numbers are visible through the paint.
Those angle blade fittings were a WEARING part in all of those early Cat angling blades.
