Main clutch parts for a 22?
Thank you received: 113
2 years 1 week ago #242537
by GrantJ
I am pulling the engine next week to add a ring gear for electric start. I want to change out the pilot bearing, throwout bearing and clutch disc while it is apart. I am going to call Florin Tractor (I think they are still open) but can anyone suggest other sources that might have parts for the 22? Thanks, Grant.
Thank you received: 9
2 years 1 week ago #242539
by TooManyIrons
I replaced the clutch/pressure plate and T/O bearing my my Cat 22 back in 1990 and sourced the parts from a shop in West Sacramento, CA that specialized in heavy duty clutches and brakes.
Hopefully if Florin does not pan out, you can find a clutch and brake shop near you.
FYI - You may want to check the clutch linkage and pivot shaft for slop. I had to have a weld shop weld mine up to remove the slop.
Current: D47U turbocharged w/Holt angle blade
Past: 22 Wide Gauge w/Cable Blade, D25U, D45T w/Bucyrus Erie straight blade, D45T Orchard, D45T w/Cat straight blade.
Priest River, Idaho
2 years 1 week ago #242542
by GrantJ
Im about to call Florin and see what they have. I think the disc can be relined if none are available but the pilot bearing seems to be a roller bearing and that is not common. The throwout bearing is also a roller or ball bearing but that is more common so is probably available. I will definitely check for slop in the linkage. Everything is working fine now but I will replace what I can so I dont
later regret not doing it ..
2 years 1 week ago #242543
by GrantJ
Progress!, I have a throwout bearing coming from Florin ($35+shipping) which I think is very reasonable and I just talked to "Capital Clutch and Brake" in Sacramento who will reline a clutch disc for between $65 and $115 depending on the size. That also sounds like a good price. Depending on the condition of the disc, I may or may not have it relined. Wont know until I pull it. Now if I can find a pilot bearing I will be more comfortable pulling it apart. I hate the thought of pulling the engine and having to wait days or weeks for a part. I am still open to hearing about any other possible parts source. Thanks, Grant.
Thank you received: 215
2 years 1 week ago #242548
by TooManyIrons
That is great news and glad to hear the Capital Clutch and Brake is still in business!
Priest River, Idaho
2 years 1 week ago #242562
by GrantJ
Bruce, Thanks for reminding me. I had not even thought of it. I will call Florin again tomorrow and see about the clutch brake. OOPs, I just tried to look up the clutch brake and can not find it in the 22 parts book. Because there is no service manual for a 22, I have a 15 service manual that shows how to adjust the clutch brake. I have been told that most of the 22 and 15 are the same, but I dont have a 15 parts manual. Am I looking in the wrong section in the 22 parts book ???
Just another confusing moment. Grant.
Thank you received: 54
2 years 1 week ago #242568
by Peter C
Grant,
Look in the 22 parts book at the transmission showing the gears from the side view for your serial number. I think what you are looking for--the clutch brake--is V-129 disc or facing. It is part of V-407 flange assembly.
Pete
2 years 1 week ago - 2 years 1 week ago #242599
by GrantJ
I will look in my parts book when I get up to the ranch. I may have to call Florin again today. At this point I am just hoping that my pilot bearing is good because Florin checked every dealer that they are tied into and said not available. Everything about my clutch works fine but I think I should replace whatever that I can so I dont have to pull the engine again at some later date. Thank you Bruce. The help on this forum is wonderful. Grant. I just saw Peters post also. Another big thanks
Last edit: 2 years 1 week ago by
GrantJ.
