Cutting edge and End Bits - Australian D4 7U
2 years 1 month ago #242466 by ozzie6677
Hi guys wondering if you can help me out.  I am looking for a cutting edge and end bits for an Australian 9F2345 Blade Group.  The parts manual lists part number IJ6 as the part number for the cutting edge and IJ127 (RH) and IJ128 (LH) for the end bits.  I believe these blades were made in Melbourne Australia.  My local Cat dealer is struggling to find the parts.  It seems most cutting edges are now 6" centres and this one is 4".  Any help or advice will be much appreciated.  Cheers
2 years 1 month ago #242468 by Rome K/G
May have to just flip the center edge, the end bits not sure, they dont show end bits with five holes in them, just three and in line with the center edge bolt holes. Odd
The following user(s) said Thank You: ozzie6677
2 years 1 month ago - 2 years 1 month ago #242469 by rax200
Hello ozzie6677,
I just brought cutting edges for my 7U earlier this year from Cat, the part numbers have changed.
I keep a list of updated numbers and at the bottom you will find them.
1J16 should be 1J6 (typo)
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 2 years 1 month ago by rax200.
2 years 1 month ago #242473 by Deas Plant.
Hi, ozzie6677.
You could try these:
www.cuttingedges.com/
earthmovingunlimited.com.au/earthmoving-...edges-grader-blades/
wearco.com.au/products/earthmoving-and-ground-engaging-tools/
www.pixeld.com.au/portfolio/cutting-edges/
Will that do for starters?
Hope it helps.
Just my 0.02. (All the way from sunny California.)
2 years 1 month ago #242474 by Deas Plant.
2 years 1 month ago #242489 by trainzkid88
they are reverible so if not allready done turn em over. the bolts are available at all good bolt suppliers. there called plow bolts.
2 years 1 month ago #242490 by trainzkid88
yours hasnt been reversed so you can do that. good idea to change the bolts. and give em a smear of anti-sieze before install make life easier next time. it also allows a proper tightening.
2 years 1 month ago #242495 by Wombat
Your cutting edge hasn't been turned, so it will go again if you use the unused side. The corner tips are a problem, maybe try an after market supplier like Cutting Edges, or you could build up with some good quality steel.. I often used worn corner tips of a larger tractor, cut out a section and welded onto the smaller end bit.
Wombat
2 years 1 month ago #242496 by PhilC
You could also weld up the holes in the blade for the end bits and redrill them to suit the new end bits.
Your old end bits look like the type found on cable blades which help to pull the blade into the ground wheres the ones shown by Daryl are more suited to hydraulic blades.
My father always said the end bits were critical in getting a cable blade to cut properly.
2 years 1 month ago #242497 by ozzie6677
Thank you so much - that is a huge help!
Time to create page: 0.186 seconds
