- Thank you received: 121
Ah OK thanks for that info. As I said I have never worked on one so I did not know it is such a huge job to access the clutches.
Hello Markds3
I may be wrong as I have never worked on a D2 but if you are only working on the clutches and the bevel gear then you shouldn't need to break the tracks.
Regards
Phil
The D2 is notoriously difficult compared to the larger tractors (D4 included) as the only way to access the steering clutches is to pull the final drives, and to do that you need to remove the tracks, track frames, pivot shaft and drawbar.
Thanks Bill, apparently they are the correct master pin, and are exactly what CAT would supply today if I ordered new ones. I just have no idea why the RHS one was so tight (maybe many years of accumulated dirt and rust?) as the LHS moved much easier and let go with only a small pop.I would consider using a standard master pin when you assemble the tracks. The pin you took out, was pressed in like the other pins and not a correct master pin. Then you won't have any future problem spitting the tracks. Bill
support@acmoc.org
- Chris R
- Jason N
