Can anyone help me with the master pins on my D2 5U
2 years 1 month ago - 2 years 1 month ago #241313 by Markds3
I've got my 1950 D2 5U home ready to strip the back end down to replace the steering clutch packs, thrust bearings and bevel gear shaft bearings. However, I am trying to identify what type of Master pin I have. Both sides have a hole drilled in a short distance (the hole on the inside is slightly larger than the outside), but the holes aren't threaded, and I can't see any evidence of the end of a tapered plug. Can any help me with the type of master pin I have and the correct procedure to remove them?
Last edit: 2 years 1 month ago by Markds3.
2 years 1 month ago #241314 by PhilC
Hello Markds3
I may be wrong as I have never worked on a D2 but if you are only working on the clutches and the bevel gear then you shouldn't need to break the tracks.
Regards
Phil
2 years 1 month ago #241315 by bruce oz
2 years 1 month ago #241316 by Wombat
you have the pin with the large and small plug, you drive the small plug in and drive right through to drive the large lug out.
Wombat
2 years 1 month ago #241325 by Markds3
Hello Markds3
Regards
Phil
The D2 is notoriously difficult compared to the larger tractors (D4 included) as the only way to access the steering clutches is to pull the final drives, and to do that you need to remove the tracks, track frames, pivot shaft and drawbar.
The following user(s) said Thank You: bcwayne
2 years 1 month ago #241326 by Markds3
Wombat
Thanks Wombat,
I'm a little stumped as from what I can see from my Servicemen's reference book:
I should be able to see the end of the tapered plug from the end of the master pin, at least the smaller plug, i.e. the plug should at least be slightly recessed or proud of the end of the master pin, somewhere where I have indicated with the red circle below, however I can see nothing, even with cleaning up the end of the pin:
2 years 1 month ago #241327 by Rome K/G
Thats a late style master pin, they put the recesses in to locate it on the rails. Doesn't look like it was hammered in enough on the one side.
2 years 1 month ago #241328 by Markds3
Thanks Rome, so to remove it you just pound on the end until it drifts right through? I've been trying with a brass drift and a sledge hitting it as hard as I can and I can't get it to budge, any suggestions?
2 years 1 month ago #241331 by Rome K/G
You can try heating the pin boss on each side and maybe put a wood beam and jack to the other side track to support it better. Where you located? I have access to a pin press.
The following user(s) said Thank You: Markds3
2 years 1 month ago #241332 by Markds3
Thanks Rome, appreciate your offer to help. I'm in Nelson, New Zealand. I think I'll try some heat first.
