HY YELLOW
HY YELLOW
Thank you received: 13
2 years 3 months ago #240181
by rturn3060
i KNOW THIS HAS BEEN DISCUSSED BEFORE AND I SHOULD HAVE TAKEN NOTES, BUT I NEED A SOURCE FOR HY YELLOW PAINT THANK YOU IN ADVANCE
Thank you received: 60
Thank you received: 999
2 years 3 months ago #240187
by rturn3060
Thank you Hillibilly, I am prepared for the n/a Ca regs. Petereson in klamath falls and Cashmen in reno both said 4C185 wasn't a good no.
Fat Dan
Thank you received: 215
Thank you received: 789
2 years 3 months ago #240197
all paint companies have old cat yellow as part of their equipment enamel line up. and you can buy sample cards from the acmoc store. it is still used however for school buses and the like as DOT highway yellow. safety yellow is also very close. any paint shop can mix the colour for you from formula. and is available in lead or lead free formulations.
the secret is dont over thin it. use good quality thinners or shellite. remember 3 coats to get a full colour. with enamels it helps to mix up 4lt of colour at a time a empty paint tin is useful for this to give more consistent results.
Thank you received: 124
2 years 3 months ago #240209
by side-seat
Finding a problem getting yellow paint for a D4 we're restoring right now.
Ended up using Rustoleum Caterpillar Yellow with some hardener added.
Thank you received: 36
2 years 3 months ago #240220
by sheddcanyon
what's the benefit of going with enamel as opposed to a single stage urethane (or two stage urethane for that matter)?
2 years 3 months ago #240221
by rturn3060
Hillibilly, Tallmans tractor supply is out of stock, found rustolium on internet at $101 but out of stock at $82
HY YELLOW
Time to create page: 0.195 seconds
