Caterpillar Twenty Two electric starter options?
Thank you received: 663
2 years 1 month ago #241171
Kristof, you can fab up a rolling handle by slipping a pipe sleeve over the existing handle that can spin. But to answer your question, Chad Enyeart in WY probably has some genuine crank handles. You also need a leather strap with a loop riveted in one end, and a 3/8 hole in the other end, and you bolt the strap to the front of the radiator, and when the crank handle is not in use, you hang it up so that it's not hanging down and in danger of being damaged by terrain
Thank you received: 19
2 years 1 month ago #241181
by tkgeorge99
OK. That's different than I thought. The manual shows the guy putting his right arm on radiator and it looks like crank is around 12 o clock position and he's pulling it towards him. So I figured if I engaged crank at about 11 o clock, I could pull it towards me while moving my body and face away from crank and letting it disengage around 3 or 4 o clock. But you are saying engage it around 6 and pull up toward 12? Just to make sure I'm on same page, crank turns clockwise if you are looking at tractor from the front. Perhaps someone would be so kind to link a video of someone doing it properly. Sometime a video is worth a thousand words
2 years 1 month ago #241182
The actual location will depend on a combination of where the crank sits between compression strokes across the cylinders, where the crank dog is oriented on the crank, and the position of the lugs on the crankhandle. Don't sweat the exact position too much - so long as you pull it over the top more or less, you're fine
kracked1
