- Thank you received: 194
You might be supersized how hardfast ice can stick. The most wear I have seen on my 8T and 9K was to the caps bolt holes they had been oblonged and bolts broken off. I was thinking at first the bearing spinning would cause damage to the shaft or beveled surfaces, however, the caps bolt holes, zerk extensions and bolts seemed to take the lion shear of the damage. The bolts looked like they had been replaced and tightened multiple times. The bolted cap can only hold the bearing so tight against the bevels. I'll get a picture of the finished product as soon as IGood to know Dan. Explains a good bit. I'd expect it would require a bit of wear in the bearings to allow them to spin? As if any of these machines were only used to blade the road to Sunday school each week....
support@acmoc.org
- Chris R
- Jason N
