D4 at Auction
2 years 6 months ago #237778 by npalen
D4 at Auction was created by npalen
This unit is up for auction locally and curious about what year it is.  I can't quite make out the prefix on the SN plate but I want to say its a 4U4866.  Would the 4U be correct?  The tractor shows 33XX hours and I believe its the wide gauge.
2 years 6 months ago #237782 by Rome K/G
Replied by Rome K/G on topic D4 at Auction
Thats a 7U series, looks like late 40's to early 50's. Five roller track frames, Dakota blade.
2 years 6 months ago #237787 by npalen
Replied by npalen on topic D4 at Auction
Does that look like original undercarriage based on 33XX hours?
2 years 6 months ago #237788 by Rome K/G
I would say yes, original shoes, lock washers with the track bolts, good rail height and good sprockets. But might have been replaced many years ago.
2 years 6 months ago #237789 by Rome K/G
Does it have an equalizer spring or a rigid cross frame under the engine? With that side air cleaner, it may have been set up for a pipelayer, Trackson PD4
The following user(s) said Thank You: npalen, Fat Dan
2 years 6 months ago #237793 by npalen
Good question, I will have to look. What applications would each be used in? (spring vs rigid)
2 years 6 months ago #237802 by GrantJ
Replied by GrantJ on topic D4 at Auction
Does that high fuel tower make it look like earlier than a U-series? I thought that the G-series had the tall tower and the U-series tower was lower. It may just be my bad memory.
Grant.
2 years 6 months ago #237804 by Deas Plant.
Replied by Deas Plant. on topic D4 at Auction
Hi, npalen.
The rigid cross members were used on sidebooms and track loaders. Bare tractors and dozers used the equalizer spring to allow oscillation of the track frames.
2 years 6 months ago - 2 years 6 months ago #237816 by npalen
hansenonlineauction.hibid.com/catalog/36...le/?q=912&m=1&ipp=10
This links to the auction which is today. I noticed two sets of hydraulic quick couplers on the back which are apparently controlled by the two handles on the right of the seat.
A third valve handle is probably for the dozer. The quick couplers would seem to be for a drawn implement but I see little to no wear on the drawbar pin hole.
Last edit: 2 years 6 months ago by npalen.
2 years 6 months ago #237821 by Rome K/G
I zoomed in on the pics and you could see it's a rigid frame, it was probably ordered for a track loader to be put on it but somebody decided to just put a blade on it. It has the heavy frames on the inside of the idlers for a loader frame also.
