D4 at Auction
D4 at Auction
Thank you received: 8
2 years 6 months ago #237778
by npalen
This unit is up for auction locally and curious about what year it is. I can't quite make out the prefix on the SN plate but I want to say its a 4U4866. Would the 4U be correct? The tractor shows 33XX hours and I believe its the wide gauge.
Fat Dan
Thank you received: 999
2 years 6 months ago #237782
by Rome K/G
Thats a 7U series, looks like late 40's to early 50's. Five roller track frames, Dakota blade.
Fat Dan
2 years 6 months ago #237788
by Rome K/G
I would say yes, original shoes, lock washers with the track bolts, good rail height and good sprockets. But might have been replaced many years ago.
Fat Dan
2 years 6 months ago #237789
by Rome K/G
Does it have an equalizer spring or a rigid cross frame under the engine? With that side air cleaner, it may have been set up for a pipelayer, Trackson PD4
2 years 6 months ago #237793
by npalen
Good question, I will have to look. What applications would each be used in? (spring vs rigid)
Fat Dan
Thank you received: 113
2 years 6 months ago #237802
by GrantJ
Does that high fuel tower make it look like earlier than a U-series? I thought that the G-series had the tall tower and the U-series tower was lower. It may just be my bad memory.
Grant.
Fat Dan
Thank you received: 930
2 years 6 months ago #237804
by Deas Plant.
Hi, npalen.
The rigid cross members were used on sidebooms and track loaders. Bare tractors and dozers used the equalizer spring to allow oscillation of the track frames.
2 years 6 months ago - 2 years 6 months ago #237816
by npalen
hansenonlineauction.hibid.com/catalog/36...le/?q=912&m=1&ipp=10
This links to the auction which is today. I noticed two sets of hydraulic quick couplers on the back which are apparently controlled by the two handles on the right of the seat.
A third valve handle is probably for the dozer. The quick couplers would seem to be for a drawn implement but I see little to no wear on the drawbar pin hole.
Last edit: 2 years 6 months ago by
npalen.
2 years 6 months ago #237821
by Rome K/G
I zoomed in on the pics and you could see it's a rigid frame, it was probably ordered for a track loader to be put on it but somebody decided to just put a blade on it. It has the heavy frames on the inside of the idlers for a loader frame also.
npalen
D4 at Auction
