D6 U/C and recoil spring
Thank you received: 660
2 years 6 months ago #237990
Martin, what's your plan for replacing the spring center bolt? I'm toying with either putting the assembly in a press or making a saddle arrangement to take the weight so I can undo the old bolt/nut for the D2 spring
Fat Dan
Thank you received: 84
2 years 6 months ago - 2 years 6 months ago #238009
by mog5858
Neil well it depends if I have to do something on the cat I think it will be all thread and 2 horseshoes plates to compress it but if I have it out I would use the 100-ton press at work to compress it so I could work on it or change the rod.
Last edit: 2 years 6 months ago by
mog5858. Reason: spelling
Fat Dan
2 years 6 months ago #238017
Thanks Martin, would you put some kind of a safety tether around it in case it jumps out? Will you torch off the nut or just unscrew it? I'm pretty sure my spring nut needs to be cut off - it's just about a shadow - frankly, I don't know how it's still holding. The other idea I had was to put it in a hole in the ground with sand maybe so that when the nut lets go, it just thumps into dirt. My understanding is that the spring is only compressed less than an inch so while it has a lot of stored energy, the movement is slight
Fat Dan
Thank you received: 788
2 years 6 months ago #238028
yes i would put a heavy chain around it too use shackles to join it not hooks, just in case and work slowly keeping yourself out of the line of fire if it lets go suddenly it could be fatal.
Fat Dan
Thank you received: 143
2 years 6 months ago #238031
by bursitis
I am not brave enough to unleash a recoil spring. i would torch cut the old one to release the tension before i removed it then get a replacement from a salvage yard. if i was to attempt it at least make a big pipe to put it in so if it gets wild at least it will not jump on you.
Fat Dan
Thank you received: 239
2 years 6 months ago #238034
by Mike Meyer
Thanks for the youtube, that spring got compressed a loooooong way, like 6" at least, that thing was a cannon ready to fire off at any moment, but he got it done without killing himself, well done!
Fat Dan
2 years 6 months ago #238035
by bursitis
in the video he mentions 800 dollars to have Cat assemble it for him? sounds cheap to me. I was impressed with the new parts though.
Fat Dan
2 years 6 months ago #238039
by Mike Meyer
Yes, I was thinking that too, there's times for saving a buck, and there's time for being smart, having that home made compressor blow apart because his welds or the Chinese allthread let go and take your head off, isn't worth the money saved, because his new parts would have cost 3 times $800 I'm guessing with freight included.
Fat Dan
2 years 6 months ago #238095
by mog5858
I had some time today so I went after the rollers on the other side of the cat. I am a very lucky guy I only broke 2 bolts off getting all the roles out and they were both on the same roller and side. now I got to go through and see what is salvageable. the game plan for the other side is to take the whole track frame off the cat so I can weld it up properly and work on the spring and the track tensioner. not sure if I really need to take the track frame off it will definitely make the welding easier and if I brake a bunch of bolts off in the rollers I will be glad I did but it sure seems a little extreme this dam cat was to get a clutch job and an oil change and go to work. lol, side note I got my rain cap for my 950 today sometime it's the small victories that keep us going.
Fat Dan
Time to create page: 0.197 seconds
