Off Topic Little Giant C32 crane.
2 years 11 months ago #234272 by bursitis
that's great. so your problem is in control group 20? one track is disengaged ?
2 years 11 months ago #234279 by hfdzl
I was under the carbody one track is disengaged or not not able to return because of a bad air can, so I don't know at this point.
So how do you get control group 20 ?
Thanks,
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
2 years 11 months ago #234280 by bursitis
i the
illustration number 20 is the control group
2 years 11 months ago #234281 by hfdzl
You must have different literature. I am using the parts book fig. 4, part #C21240
2 years 11 months ago #234282 by bursitis
After getting a headache from looking at all the parts sheets, I think this is correct or close to correct as my old brain can comprehend. Will actually verify when I get my road trip.
i was referring to this one
2 years 11 months ago - 2 years 11 months ago #234283 by hfdzl
   OK I see see  your point. I am referring to #5 here- yes it's upside down but what you would actually see.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Last edit: 2 years 11 months ago by hfdzl.
The following user(s) said Thank You: steve_s
2 years 11 months ago #234285 by bursitis
in figure 4 you can remove pin 24 that disconnects the linkage from the air cylinder and rotate number 34 so that number 41 engages number 42.  if the brake number number 51 in figure 5 is holding then you can loosen number 49 and 50 on bolt number 48 to release the brake. then the crane should track straight and you can use the non affected side to steer???
2 years 11 months ago - 2 years 11 months ago #234286 by hfdzl
you are ahead of my post. yes that would work
I just called Empire Crane in NY, gave them the part numbers. They are going to make request. Lets see how parts support is!
Herb
Time to create page: 0.167 seconds
