Off Topic Little Giant C32 crane.
Showing 1 to 10 of 37 results
hfdzl
I realize [attachment=65827]Little Giant C32.jpg[/attachment] [attachment=65828]little giant.jpg[/attachment] this is not mainstream Caterpillar talk. There is a 1987 Little Giant C32 crawler crane that I am interested in. The machine is easy to get to. The problem is that supposedly it will not walk. I am looking for any information, books, literature and or personal knowledge for such. I do collect other orphans of unique interest.
Thanks for your time in reading this. Help a collector with bad iron deficiency!
Thu, Dec 16, 2021 3:37 PM
bursitis
that is a nice little crane. i wish it was near me. i don;t have much experience with little giant but am happy to try to help if i can. most cranes are similar
Thu, Dec 16, 2021 8:35 PM
Thank you received: 30
Reply to bursitis:
Rainy day here to much time to think about what never crossed my mind. What or how was power transmitted before hydrostatic drive.
Thu, Dec 16, 2021 11:28 PM
hfdzl
Reply to Ray54:
Detroit 4-53 with mech. over center clutch. Supposedly the machine will not travel, I am thinking it got to where it is. So?? Trying get more info before I go down to see it. I know I am bringing fuel and a hot battery ! More road trips and old iron !
Thu, Dec 16, 2021 11:39 PM
Reply to hfdzl:
Herb, there's a decent set of videos on youtube for a fellow named Jonathan W who resurrected a Unit crane, which has a lot of common features with your one - Detroit, all mechanical. If you take a swing through the videos, it might provide some additional intel on yours. For instance, in his crane, he couldn't engage the dog to drive the crane, and a clutch mechanism required freeing up to gain all the travel it needed to be adjusted properly. It's not specifically what you're looking for but it might help hopefully.
Thu, Dec 16, 2021 11:59 PM
And this link to an excavator owned by a Tim Hoover who displays it at the HCEA show in Simcoe Ontario each year. He may have some literature and even though it's a digger, it could well have a similar undercarriage. The video says that he had to fully rebuild his undercarriage and drives so he would know a lot about them and might be able to help you trouble-shoot.
https://www.youtube.com/watch?v=hztUAuzcA8g
Fri, Dec 17, 2021 12:06 AM
bursitis
you need to determine if it is an independent swing and travel machine or if the swing clutches are used to travel the machine. my guess if with the dozer type undercarriage that the swing and travel are independent from one another. could just be a rusty frozen linkage or dog clutch.
Fri, Dec 17, 2021 1:48 AM
hfdzl
Reply to bursitis:
Neil, thanks for the video, I did follow Johnathan W That was interesting and more enjoyable in that he found the right parts to repair the machine.
bursitis, I am still digging for info, have contacted HCEA archives, to see what they have. I don't know what style travel system they have, I do know it is air control.
Thanks everyone
Fri, Dec 17, 2021 2:56 AM
bursitis
Reply to hfdzl:
Thanks everyone
https://www.manitexinternational.com/brands-littlegiant.aspx
give them a call with the model and serial number
Fri, Dec 17, 2021 3:45 AM
hfdzl
Reply to bursitis:
I already have contacted my local dealer. They have supplied many pages of parts documents. but no operators manual. It is a start to the library.
Fri, Dec 17, 2021 4:03 AM
bursitis
Reply to hfdzl:
before you try to start it you should prepare for a runaway by having a board to cover the air intake. look at the levers or air controls, there should be a swing lever a crowd lever and a hoist lever,sometimes the hoist lever doubles as a boom lift also unles it has a live boom. if there is another then the chance that it has independent travel is high. find the main clutch lever ans once you get it started and build air pressure just feather the levers until you figure out what lever does what. if the travel and swing are tied together there will be a nother lever probably below ant to your right that lifts a dog clutch that sends power from the swing clutches down the center to the bottom.  take some pics of the controls??? and the works?
Fri, Dec 17, 2021 5:23 AM
