Pony motor
3 years 3 months ago #230211 by mog5858
Replied by mog5858 on topic Pony motor
Bottom right hand side is the water pump. By the red arrow.
The following user(s) said Thank You: Pyobluebonus
3 years 3 months ago #230213 by Pyobluebonus
Replied by Pyobluebonus on topic Pony motor
I didn't know that. Is that a good motor for sale?
3 years 3 months ago #230223 by Pyobluebonus
The pony motor started however it won't run at full speed. To make things worst the pony motor clutch engaged and the cat motor spins also how do i disengage the clutch so the diesel motor won't turn until the pony motor starts?
3 years 3 months ago #230224 by neil
Replied by neil on topic Pony motor
Well, like you wrote, you can disengage the clutch using the pinion clutch lever. But you probably meant how to disengage the pinion - reach into the clutch compartment (or go through the adjustment opening) and squeeze the latch arms together to unlatch the pinion assembly. The pinion will release - watch your fingers because it will unlatch with some force.
3 years 3 months ago #230236 by Pyobluebonus
Neil do you have a picture of the cover or where it is located?
3 years 3 months ago #230265 by trainzkid88
Replied by trainzkid88 on topic Pony motor
note you need to use wire cored plug cable not silicon suppression. and crimp on metal ends the modern stuff doesnt work well with these old magnetos.
clean the spark plug mating surfaces and threads bad contact equals bad spark take the mag off and clean its mating surfaces too rub them lightly with 2 b pencil and reinstall while its off check the timing gears for correct position they can be put on 180 degrees out.(the graphite improves contact)
check the valve timing although if it was running properly before mag failure it should be fine unless someone has stuffed with it too. check the valve tappet clearance adjust to spec.
3 years 3 months ago #230266 by trainzkid88
are you sure you have the throttle and choke levers in the "right" position they are different to what you might think. and each engine has it favourite spot.
3 years 3 months ago - 3 years 3 months ago #230267 by trainzkid88
ive had the pinion engaged when starting once the pony fired the main stopped turning as the throw out released.  I then engaged the pinion and clutch as normal after the pony had warmed sufficiently. it doesnt hurt any thing its just harder to pull over the pilot via the rope.
note these do have a clutch brake if you push the clutch lever forward the brake stops the pinion spinning so ring gear engagement is smooth the pinion is engaged when the pinion lever has no weight on it. the pinion lever is in front and underneath the clutch lever
Last edit: 3 years 3 months ago by trainzkid88.
3 years 3 months ago #230268 by Pyobluebonus
Pony stoped and the pinion wont disengage now not sure how to disengage the pinion.
3 years 3 months ago #230269 by Pyobluebonus
The pony motor runs for 30 seconds then dies not sure what else to do rebuilt carb still not running for more than 30 seconds.
Time to create page: 0.193 seconds
