Help with hydraulic system
Thank you received: 16
3 years 6 months ago #228609
by Xtremist
Hey Guys
Im trying to figure out what is on my D6 9U for a hydraulic system, I cant seem to find any numbers any where. The little bit that ive found on the net says that they had a #46 system on them but my question is, is that what every 9U had on it ? Ive overhauled most of the cat and modernized it quite a bit and im on the down hill slide of the reapairs. I need to figure out why the blade wont stay up. From all the way up its on the ground in a matter of seconds... So if anyone has any info on the hydraulics of these old girls id be very appreciative if you shared lol.
Fat Dan
Thank you received: 929
3 years 6 months ago - 3 years 6 months ago #228610
by Deas Plant.
Hi, Xtremist.
If you can post some photos of what you have, I am pretty sure that somebody smarter than me will be able to identify your system. Not all Cat crawlers had Cat systems. There were a goodly number of after-market systems too.
Azfer your rapidly descending blade rams, that could be worn ram piston seals, wrongly set or failed relief valve or bypassing in the control valve, or any combination thereof, though it would HAFTA be a helluva bypass in the control valve to cause that quick a drop.
I'll let those with more knowledge than me step in here now.
Thank you received: 789
3 years 6 months ago - 3 years 6 months ago #228625
if the rams are like those fitted to d46/7u series they have valves in the piston if these are faulty that could be the cause.
i would be looking at the rams first. it is cheaper to replace the ram shaft than to recrome it if scored or pitted. seal kits for the rams are available as we had ours redone. our machinist cut the eye off the old shaft, machined a new bit of bright shaft to size, threaded it and after centreing the whole thing in the lathe welded the eye to the new shaft, then skimmed the weld smooth worked out to be the same cost to do both as the quote just to recrome ONE old shaft let alone labor and parts to dismantle and then rekit the ram
3 years 6 months ago #228639
by Xtremist
heres a few pictures, if that helps. One ram is leaking bad, the chrome is all buggered up, and i have a parts cat here so ill throw on a different cylinder but i would have thought that even just one should hold up the c frame and dozer......? on a totallly unrelated note does anyone know what a track group (rails/30'' pads) weigh for a d6c ?heres a few pictures, if that helps. One ram is leaking bad, the chrome is all buggered up, and i have a parts cat here so ill throw on a different cylinder but i would have thought that even just one should hold up the c frame and dozer......? on a totallly unrelated note does anyone know what a track group (rails/30'' pads) weigh for a d6c ?
Fat Dan
Thank you received: 187
3 years 6 months ago #228641
by Fat Dan
whoops not sure why there are a bunch of sets of the same pictures.
I'm not sure eather but every time I add a pic then cut and past it doubles the pics ... It helps to add pics last
ACMOC Member
Thank you received: 663
3 years 6 months ago #228653
The tech team have been notified about this doubling issue. I don't think they've identified a solution yet. Meantime, what you can do is delete the doubled references in the editor
Fat Dan
Thank you received: 348
3 years 6 months ago - 3 years 6 months ago #228654
by seiscat
Hi Xtremist, Back in the day Caterpillar had a wierd system of having a seperate Parts Book for each attachment/system. I don't have the Parts Book for the basic No.46 hydraulic system but I do have the Parts Book for the 6A & 6S blades, oddly the hyd. cyl. parts are listed in that book. I have attached all three pages as I don' know your S/N.
Craig
Last edit: 3 years 6 months ago by
seiscat.
3 years 6 months ago #228656
by Xtremist
id love to track down a book as soon as i can figure out what it actually has for a system....is it a #46 ? the serial number on this machine is 9u2657 so its an earlier one....
Fat Dan
3 years 6 months ago #228658
by seiscat
I just edited the pictures in my last post and rotated them.
The parts book you need is the Caterpillar No. 46 Hydraulic Control Parts Book. These books are sometimes available on ebay, just keep looking.
Your rapid blade drop can be caused by several things but the most obvious is the failure of the lift cyl. lift rod seals causing a low oil situation. Prolonged operation with low oil will cause pump failure.
While you shop ebay also look for the Caterpillar Operation and Maintenance Instructions for your machine, it will save you time & money.
Craig
