Photo's from a Bygone Era
Thank you received: 1544
3 years 5 months ago #223998
by seyser
6-29-40
Levi H Yerger
Lititz, Pa
Caterpillar Diesel D2 tractor and LaPlant-Choate roadbuilder removing silt from creek bottom on a farm near Mt. Joy, Pa. This location in the stream is used as a ford for automobiles. The material is moved to the bank then loaded into trucks. Tractor working 10 hours a day on about 6 cents worth of fuel per hour.
3 years 5 months ago - 3 years 5 months ago #223999
by seyser
1946
Michigan TR. & MCHY. CO.
Caterpillar diesel D4 tractor with trackson pipe-layer working on Marquette R.R. near Howell, Michigan.
Last edit: 3 years 5 months ago by
seyser.
3 years 5 months ago #224050
by seyser
11-2-51
Loop of 20-ton anchor chain is pulled by four Caterpillar D8 tractors to clear Ceylon jungle for Gal Oya project. Area to right has already been cleared by chain.
Thank you received: 903
3 years 5 months ago #224072
by Deas Plant.
Hi, seyser.
Didda bitta that in my younger days, used everything from D4s to D8s. The 2 X D8s once took down 6,500 acres in 5 X 13-hour days - around 100 acres an hour.
It sure does help if you have a good man on the other tractor. LOL.
Just my 0.02. Thanks for sharing.
3 years 5 months ago #224084
by seyser
Hi Deas,
I’ll bet that was quite a job. Sounds like those D8’s would move at a pretty good pace.
Fat Dan
3 years 5 months ago #224091
by seyser
August 15, 1947
Laying rails on new grade to serve roundhouse for the Chesapeake and Ohio Railroad (Pere Marquette District) Diesel locomotives in the "Wyoming" yards at Grand Rapids, Michigan. Caterpillar D4 tractor equipped with Hyster side boom handles 39' rails weighing 110 lbs. per foot. The D4 also works with stoneboat to distribute material for new trackage.
3 years 4 months ago #224138
by Deas Plant.
Hi, seyser.
It was all 2nd gear work with 2 X 270 hp powershift D8Hs pulling 600 feet of 2 1/2" chain cutting around 400 feet wide in scrub 10 to 12 feet high - mostly only got to see each other at the end of each run. THAT is when you REALLY need a good man on the other tractor.
Fat Dan
Time to create page: 0.466 seconds
