Precombustion chamber interchangeability
Thank you received: 9
4 years 2 months ago - 4 years 2 months ago #222376
by TOGNOT
New/ used pre chambers arrived. I will get all the measurements before they are installed so we can compare them to other cat models.
Last edit: 4 years 2 months ago by
TOGNOT.
1 year 1 month ago #251953
by BuffaloLou
Three years on and I am helping a friend locate pre combustion chambers for his 1941 3J5471-SP D2 dozer with a 1947 5J9658-SP engine. On removing the existing chambers one broke off at the thread, and a couple were rusted through. The chambers appear to be 101.71mm in total length with a 1" thread at the bottom and an external diameter at the top of 55.22mm. Has anybody got any spares lying around (grasping at straws) or can suggest a suitable replacement with or without further machining? Cheers - Lou
Thank you received: 818
1 year 1 month ago #251969
by BuffaloLou
Thanks Old Magnet! Just to confirm, is the pre combustion chamber I am looking for (pictures on my last post) the newer type? It has a 12-point hex inside which I assume is the means to install or remove the chamber. I gather that there was an earlier type with a reverse thread for the installation and removal. And it is the newer type that is part number 8B4440? Cheers - Lou
1 year 1 month ago #251975
by BuffaloLou
Thanks Old Magnet, appreciated. That makes it clear now.
Regal USA have advised that the 8B4440 is no longer a stocked item, so still on the hunt!
Cheers - Lou
1 year 1 month ago #251994
by BuffaloLou
Thanks once again, Old Magnet!! I am following this one up as well. Your assistance is very much appreciated!! Cheers - Lou
Time to create page: 0.167 seconds
