Precombustion chamber interchangeability
Thank you received: 9
4 years 2 months ago #222214
by TOGNOT
I’m still looking for a precombustion chamber for my D2 3J. I have a couple leads, but in the meantime I wondered :
Are there other prechamber that maybe don’t fit ( exactly) but would with a little machine work ? Several companies make after market chamber for the bigger cats, that’s why i ask.
Thanks for any ideas.
Thank you received: 236
4 years 2 months ago #222221
by d2gary
This is totally from memory so I can't verify any of it but I read it on the bulletin board in the past. Someone was having similar problems locating precom for a d2 and it was suggested that a d4 chamber could be turned and rethreaded to fit a d2. I don't know if this was d4400 to d3400 or if the u series stuff will work also. I can't give you the thread pitch either. I did a couple of searches with the search option and couldn't find anything. Maybe some more knowledgeable will help out
Thank you received: 818
4 years 2 months ago #222236
Whats the bore diameter for the early chamber. If it's 2-1/8" that's the same as the early D4 which has a length of 3-1/2" from seat to top of chamber. Thread size on the D4 is 1-1/8"-12 tpi, the D2's are 1"- 12 tpi. The D4 chamber is part # 8B0493 which I believe are still available.
Any luck finding J model later chambers? Threads on the D4 chamber can be re-cut and some reshaping of the chamber transition to the threads are probably required. Basically this is the same task the rhpig offered for the later U model D2's.
4 years 2 months ago #222239
by TOGNOT
Thank you - that’s what i needed - some dimensions. I don’t have the head and the removed chamber here with me, but ill find out and report back.
4 years 2 months ago #222244
Here's a picture of an altered D4 chamber for use in the "U" model D2's as offered by jhpig on here.
Similar alterations would be required for the "J" models.
4 years 2 months ago #222245
by TOGNOT
Thanks for the picture. I found a drawing online for the part number you listed earlier ( 8B0493 )
4 years 2 months ago #222262
by TOGNOT
I think I Have some Good D2 chambers Enroute . But to follow up onthis topic :
Measuring the D2. Head :: prechamber “bore” at the top about 2 1/8”. Distance from combustion chamber to top Of prechamber sealing surface :: 4.25 “
When the new/used chambers arrive I Will Document the dimensions
