D6 9U wet clutch replacement
Thank you received: 41
10 years 3 months ago #109163
by wimmera farmer
Got a complete pump from Cat classic parts 4-5 years back would try there first.
Was going to cost heaps to get individual parts and rebuild mine.
Thank you received: 80
10 years 3 months ago #109172
by hemertwv
I have some cluch oil pump and I check if am still have one for d6 and am in CANADA
Thanks let me know if you do.
10 years 3 months ago #109177
by gemdozer
I have 2 oil pumps and on body # 4h5928 and the gear 1h8438
<a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
Thank you received: 329
10 years 3 months ago #109187
by Ray54
I don't remember there being a seal on the end of crankshaft Cat used a spiral to push oil back into engine if I remember correctly.
10 years 3 months ago #109191
by hemertwv
If that is correct that is great thanks.
Thank you received: 5
Thank you received: 10
10 years 3 months ago #109227
by ccjersey
Sounds like you need a whole used clutch assembly to me.
While it is out of the machine, check the 3/8" studs that the adjuster lock plates and nuts fit on. These are fairly commonly stripped out.
10 years 3 months ago #109441
by hemertwv
Thanks most of the clutch is pretty solid, the threads are fine, got a used oil pump on order, some plates, the rest looks pretty good after a closer inspection.
We are in Edmonton, but the D6 is in Edson, Alberta
Time to create page: 0.221 seconds
