D-4 Clutch problem
17 years 2 months ago #9413 by MHG
Replied by MHG on topic D-4 Clutch problem
OM I agree, when I had this problem I thought the teeth were gone,AGAIN, so after I could see the teeth were ok it took a bit of looking to find this problem. It was a heads up to look for something else if need be. Mike:D
17 years 2 months ago #9414 by Old Magnet
Replied by Old Magnet on topic D-4 Clutch problem
Hi MHG,
Just recently redid my clutch, even got new Cat replacement lock plates too but the lower one did not have enough meat to fold over and lock the lower pivot bolt you are referring to. Had to make my own. Definitely a fun place to get access to :) :)
17 years 2 months ago #9422 by otterden
Replied by otterden on topic D 4 Clutch problem
Old Magnet called it right the first time. After removing the inspection cover I could see broken teeth laying in the bottom.
Now for the next step. What is the least difficult way to replace the clutch disk? By the way I have a trackson loader on it which is going to make things harder.
17 years 2 months ago #9423 by Old Magnet
Ya got yourself a real project there:rolleyes: :rolleyes: ....don't know that there is an easier way. Engine out is just as bad as cover off. I've seen some nasty torch and welding approaches but I sure wouldn't recommend that. It's loader frame off as far as I know but (thankfully) I haven't had to work on any loaders.
17 years 2 months ago #9424 by SJ
Replied by SJ on topic Clutch
There isn,t an easy way to do a clutch job as it needs to be removed & depending on the year of tractor the top cover was in two pieces & at the shop we had them cut in two if they were a one piece.That cover goes from the just under the start. engine flywheel to the rear of the tractor if one piece & if two piece goes about under the front of the seat or in the vicinity. The drive coupling has to be removed between the clutch assem. & the trans. & then the clutch assem. complete has to be removed. Being an HT4 makes it a real challange as it,s tough to get leaned over to work on things in there.If the complete cover needs removing then the seat & fuel tank & whatever else on top in the way needs to be removed.
17 years 2 months ago #9425 by otterden
Replied by otterden on topic D 4 clutch
Thanks everybody for your helpfull suggestions. This project is going to have to wait untill my shop is finished and I can work inside out of the weather.
Thanks Again!
17 years 2 months ago #9426 by ccjersey
Replied by ccjersey on topic D-4 Clutch problem
Wow! Amazing that just a partial jam on the outer edge could drive the tractor at all.
Maybe you can nurse it along and get it to a good spot.
17 years 2 months ago #9427 by Old Magnet
Got to looking at the parts book (frame interference) and it's not as bad as I was thinking. Cover off would be the way to go....still a tough reach access wise. Maybe someone on the BB that has actually done a clutch job on a HT4 can add some pointers.
There doesn't seem to be any literature covering specific loader service and I get asked about this quite often. All you get is the loader parts book and the regular 7U lit. to work from.
17 years 2 months ago #9434 by bob
Replied by bob on topic D-4 Clutch problem
DON'T WORK ALONE!!!! make sure there is someone around strong enough to haul you up out of the hole if need be.
Later Bob
17 years 2 months ago #9437 by MHG
Once you get to the flywheel take a small grinder and a wire brush and clean off the rust, grease and broken fiber teeth out of the teeth on the flywheel. Also fix any oil leaks as the oil will eventually weaken the fiber clutch disc teeth.Mike
