I need one lever on the controls on a 212
4 months 3 weeks ago #258755 by Jeff M.
 I need one control lever from a 212 grader. I think it is the second one on the right side . Thanks for the help
4 months 3 weeks ago #258784 by Jeff M.
I also need the crosses in the drive shaft from the transmission case to the control box
4 months 2 weeks ago #259017 by Fat Dan
It is much easier to find the correct part if you cite the Part Number and Serial Number as well as the identification of the part. I don't have any manuals on any of the 212 models, I do know not all levers are made equal A good set of Cat manuals is a must to be able to work on your own equipment. They have an excellent online library for members here at ACMOC.
Good Luck.
ACMOC Member
4 months 1 week ago #259079 by Jeff M.
I also need the crosses in the drive shaft from the transmission case to the control box Ok Dan here are the part numbers the cross number is 6F 9741 The Lever number Is 5B 5184. We will see if that helps thanks for the help
4 months 1 week ago #259087 by josh
The cross was also used on the 8T and 7T graders and some other applications, so should be some around, also the levers on the 8T grader look like they might be similar enough to the 212 levers that you might be able to modify one to be a match.
4 months 1 week ago #259093 by Old Magnet
If your referring to the power control drive shaft for the 9Txxxx the u-joint crosses are a standard #UJ961
4 months 1 week ago #259109 by Jeff M.
Where do you find the uj961 joints at
4 months 1 week ago - 4 months 1 week ago #259114 by Old Magnet
Try SKF for the UJ961 or "google search" for 6F9741. They seem to be out there.
Plenty 6F9741's listed on machinery trader.
Last edit: 4 months 1 week ago by Old Magnet.
4 months 1 week ago #259115 by Jeff M.
Thanks for the help I got one ordered
