Wanted: D315/318 Hour Meter Shaft Assembly (Shaft & Gear)
2 years 16 hours ago #242922 by chalackd
Hi, as the title says, I'm looking for a shaft assembly (4F8130) for the hour/service meter for a D318 engine, as found in a Model 12 (8T) road grader.
Water had gotten into it and seized the shaft into it's bearing, resulting in a broken gear.  I've managed to get the shaft freed and cleaned, but from sitting in moisture the worm gear on it is thoroughly destroyed.  I had hoped to be able to swap it with a shaft/gear from a D4400, but the worm is a larger diameter on the D4400 one so will not interchange.
I suspect the brass gear is the same between the two, but they have different part numbers so I would prefer to play it safe and just find one actually from a D315/D318.
Located in Alberta, Canada, willing to pay for shipping from anywhere as long as the price isn't too crazy...
Pics included of the bare shaft I'm looking for, missing the broken brass gear, and the shaft assembly plus bearing & seal from the D4400 meter.
2 years 13 hours ago #242930 by rax200
Have you tried Florin Tractors in Sacramento? They are showing 3 in stock.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
1 year 11 months ago #243014 by captain k
Where in Alberta? I have a parts #12 near medicine hat. High serial 8T. I'd have to look but I'm sure that shaft is there.
This email address is being protected from spambots. You need JavaScript enabled to view it.
Time to create page: 0.135 seconds
