FOR SALE/WANTED
3 gauge panel
3 gauge panel
Thank you received: 89
5 years 3 months ago #204514
by bboaz
Looking for the 3 gauge panel that was on the 7M D7 and also, I think the 3T D7. I do not have a picture or a part number. Do not need the gauges, just the panel. It looks a lot like the ones on the 9U D6 (4F7733) except there are provisions for 3 gauges. Even the part number would help, then I could search sources for the panel. Thanks Brian Boaz
Thank you received: 820
Thank you received: 186
Thank you received: 663
5 years 3 months ago #204522
Is it the same as the cast 3-gauge panel on some graders? If so, I think I have one
Thank you received: 24
5 years 3 months ago #204952
by bboaz
Neil I used my old 2 gauge panel and cut it in half and added enough in the middle to make it a 3 gauge panel. I think it will work just fine. Thanks for looking, but I don't need it now.
5 years 3 months ago #204954
Hi Brian, good deal. I did look and sent a message but it might not have made it to you. I couldn't find the panel so it probably went to China
5 years 3 months ago #204977
by bboaz
Didn't get the message but thanks for looking. That worked out pretty good just adding to the one I had. This is how I mounted my one wire alternator. Made a pulley that bolted to the back of the water pump pulley and powers the alternator. Didn't affect the adjusting of the belt and put spacers in the bottom mount of the alternator so I can compensate for movement forward and backward when adjusting the water pump belt. I think this will spin the alternator a lot faster and leave the old generator drive so I can use it to run a hydraulic pump.
FOR SALE/WANTED
3 gauge panel
