#1. Servicemen's Reference Manual for Caterpillar Diesel Engines, 3 3/4" Bore 4-Cylinder. Applicable to D3400 Industrial, D3400 Electric Set, D3400 Marine, D2 Tractor (J-Series), No. 212 Motor Grader. Book is used with light cover staining and some cover tears, but cover and all pages are intact and very legible and usable.
#2. Installation and Operation Instructions for Caterpillar No. 44 Hydraulic Control, Serial Numbers 6W5001-Up, 7W1-Up, 8W5001-Up, 9W1-Up. Applicable to Installation on D6, D4, D2, and R2 Tractors. Book is used with very light cover staining, but no rips or tears, very good to excellent condition.
#3. Technical Sales/Marketing Booklet for Caterpillar Diesel Engines, Series D311 (U-series D2, D315 (U-Series D4), and D318 (U-Series D6). Contents includes discussions on the following topics: Crankcases and Cylinder Blocks, Heavy Duty Crankshafts and Bearings,Connecting Rods and Pistons, Valves and Valve Mechanism, Cylinder Heads, Cylinder Liners, Fuel System and Fuel Injection Pumps, Fuel Injection Valves, Fuel Filtering, Lubrication System (Pumps, Filtering, Cooling), Governor, Timing Gears, Cooling System, Air Cleaners, All-Weather Starting (Independent Starting Engine "Pony"). Also included are color cut-away photos of the D318 and D311 engines and color exterior photos of all three engines. Has charts showing Intermittent, Rated, and Continuous Performance and also fuel consumption charts for each series of engine, and finally, dimensions and specifications for each engine. This book is very usable and legible, but please note that there is a hole in the front cover and about the first 11 pages have a decreasingly shallow cut on part of the page, similar to what one would expect a box-cutting knife to make. Please look carefully at the photos to assess the degree of damage.
All 3 books are sold. Thank You
