D8 pony crank shaft
8 years 4 months ago #147780 by Bmr
D8 pony crankshaft was created by Bmr
I have a new old stock pony crankshaft for sale
Calls are best thanks Jon
507 402 2720
8 years 4 months ago #147825 by janmeermans
Replied by janmeermans on topic More info.....
Bmr,
I can't tell if you are offering just a shaft or does it include the crank? And for which model D8?
I need a crank for my 14A that would be similar to "deep socket with a hole drilled through it about 1" from the end with two slanted channels machined from the end into the hole lying at a angle". It would need to fit into the 90 degree pinion drive in the front of the starting motor. The crank pictured in the parts book 4H4359 doesn't look right. I borrowed a crank from off Pete Bloom's DW-21 while we were at Santa Margarita Show which fit just fine and did not have the spring as pictured in the parts book.
JanM
8 years 4 months ago #147848 by Andrew
Replied by Andrew on topic D8 pony crank shaft
I read it that he has a crank shaft for sale . !!!!
Not the shaft you use to crank the engine to start it.
That is I think what you are looking for.???
A..K..
8 years 4 months ago #147863 by janmeermans
Replied by janmeermans on topic Duh!!!
Andrew,
I think you are right. The sale item should be "crankshaft" and he confused me by making it two words. Regardless, having the model number of the D8 would help a lot. I was running a 13A yesterday that has the pony CRANK attach to a separate SHAFT going through the hood and down to the pony so my frame of mine was on that.
JanM
8 years 4 months ago #147872 by old-iron-habit
Replied by old-iron-habit on topic D8 pony crank shaft
Andrew,
JanM
Hey Jan, Seems you get more seat time now than when you were an operator.
Time to create page: 0.160 seconds
