Cat Ten pistons and rods
9 years 3 months ago #126477 by tomseabee
I have three Cat Ten rods and two pistons available for shipping. Actually I have three pistons but one of them is a bit leaky (It has no top).
tom
8 years 8 months ago #140779 by Caterpillarman
Tom, Do you still have these pistons available? If so, what size are they? I need a .060 oversize piston. Thanks, Caterpillarman
8 years 8 months ago #141032 by tomseabee
Replied by tomseabee on topic Cat Ten piston/rods
I think they are standard diameter pistons. I'll check. I guess they should be stamped if they are oversize.
Tom
8 years 8 months ago #141033 by tomseabee
I found a note on them that says they are .040" oversize. I can mike them to be sure if you want to provide me with the diameter of the .060" oversize piston.
8 years 8 months ago #141056 by Caterpillarman
Tom The piston I need would be 3.435. Caterpillarman
8 years 7 months ago #141456 by tomseabee
Replied by tomseabee on topic Cat Ten pistons and rods
I'll check.
8 years 7 months ago #141491 by tomseabee
I'll check.
Sorry, the pistons are standard.
There are rods with the pistons if you need rods.
Tom
8 years 7 months ago #141493 by edb
Replied by edb on topic Cat Pony Piston Sizes
as the early pony engines are basically one half of either a Ten, Fifteen or Twenty Tractor engine, in the scan below these sizes are for the standard oversizes offered in the past in the Cat System.
You can buy the pistons semi-finished and get a few more thou out of your bores.
Here in Australia we can get semi finished pistons from JP Pistons in Adelaide South Australia.
www.jp.com.au/JPPistons.html
Hope this helps.
8 years 7 months ago #141541 by Steve A
Replied by Steve A on topic Cat Ten pistons and rods
I seem to remember Al Smith fitted Farmall H pistons in a 10, I believe they had to make new rod bushings and bore the block.
They would be much easier to get
8 years 7 months ago #141543 by Sasquatch
Replied by Sasquatch on topic Cat Ten pistons and rods
I remember a while ago Cysco on here toyed with the idea of fitting new Farmall H pistons in a Ten engine. I don't know if he ended up doing it but I do remember there were a few fitment issues that popped up; they were around .060" taller than the original pistons when installed, and the piston pins were a bit bigger than the Cat Ten ones, but I believe it was decided that the difference was slight enough that machining the pin bushings larger would've been do-able. There was also talk of possibly machining down the piston crowns some to avoid increasing the compression ratio to the point of adding unwanted stress on the old engine, but I think that's about as far as it went.
Time to create page: 0.193 seconds
