FOR SALE/WANTED
cat ten intake valves
10 years 8 months ago #100851
by 22B
any one have any good cat ten intake valves for sale or know where to get some short of machining blanks..?
Gib
10 years 8 months ago #100853
by Canuckd2
Its been a while since I done mine, but I am sure that the valves in the vertical Starting engines are the same , 5B.5101 intake, 4B.7264 exhaust, Ken
Thank you received: 7
10 years 8 months ago #100861
by catrjw
The valve are the same used for the pony motors on the D7 or D8. When I did mine I got some from Cat, but they only had either the intake or exhast. I don't remember. I found that the Allis Challmers WD30 were a match and got them thru a local head shop. Also had to use the keepers. Worked out fine. Hope tis helps. <a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
10 years 8 months ago #100874
by Catmatt
Cat still makes the exhaust valves for a ten. Just need to know the current part number which is 4b7264
10 years 8 months ago #100875
by yancy44 mag
mine came from the stating eng from a cat 2U its been a long time they had to do a little work but i do not now what and i used the carb to it was the same the linkage was different and i had to use the linkage of the one i had and make new from pick i took from a carb on a tractor with all the right stuff
10 years 8 months ago #100905
by 22B
the number 5b 5101 for the intake is no longer available for the ponymotor, they do have the 4b 7263 intake for the 2u pony and the 4b 7264 exhaust for the 2u pony. have got one intake coming to see if it will work with a change of the keepers.. thanks all for your help if anyone has any more ideas please let me know..
Gib
FOR SALE/WANTED
Time to create page: 0.151 seconds
