Cat D318GT Engine
Cat D318GT Engine
17 years 5 months ago #7153
by Chris B. Weilep
Does anyone have a shop manual for this engine? I need some specs for it.
This is a D318GT Stationary Power Unit. It is a turbo charged 200 HP engine and was used in Bucyrus Erie Cranes among other aplications.
I need the torque specs for the Rods, Mains and Head bolts and also the liner protrusion tolerances.
I also need the injector height for setting the plunger travel and the injector length tolerance.
Chris B. Weilep
Gilmanton, WI
<a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
17 years 5 months ago #7155
by SJ
This what I have for the older D318 NA & the mains are 120 lbs. & rods 58 lbs. & the head is 130 for the bigger nuts & 58 lbs. for the smaller nuts. Also the lifter setting for the inj. pumps is 1.736" at TDC on the firing stroke for that cyl. Also the prechambers are listed as 200 lbs.in the head & the nozzle nuts are 105 lbs.If you have cotter pins in the rod & mains don,t back the nut up to get the pins in but advance (tighten nut) to the next hole showing.
Thank you received: 818
17 years 5 months ago #7158
For the missing items:
Liner protrusion .002 - .005
Plunger length new 2.6575 - 2.6577
Discard if wear exceeds .005
That's a pretty rare engine:D
17 years 5 months ago #7159
by SJ
Yes OM I forgot to include the liner projection specs. Also with the plungers it,s very important to observe if there is up & down wear (scoring) at the top of the plunger & if it shows scoring of the finish at the very top of the plunger above the groove around it.
Cat D318GT Engine
Time to create page: 0.137 seconds
