Where did the oil go?
17 years 5 months ago #7011 by Don Clark
D47U. The clutch housing where I engage the pony motor. The oil keeps disappearing. After adding oil, withing 3 to 4 starts it is gone. No oil spots beneath the tractor. Going into the main engine? What is the fix?
17 years 5 months ago #7012 by SJ
Replied by SJ on topic Leak
It seems about the only place it can go is past the rear starting pinion housing seal & going back in the diesel flywheel housing. Do you have an oil clutch in the diesel & if so it would accumulate in the clutch compartment and if it,s a dry clutch it seems you,d see it dripping out the bottom unless yours has a sealed plug. Lots of them with dry clutches has a hole drilled in the plug & a loose cotter pin in the hole so anything can drain out.If your tractor has a dry clutch take the plug out from under the flywheel if it doesn,t have a cotter pin in it & see if there is oil in there which it shouldn,t.
Time to create page: 0.127 seconds
