TEN rusty master pins
17 years 5 months ago #6427 by frenchcat
Could somebody tell me a proper method to pull out a pair of rusty master pins from my TEN tracks. Boths are in front position, under radiator, as told in the maintenance guide. I pulled out cotter pins and added plenty of degrip-oil, then I used a big hammer under a punch from inside as indicated but nothing is moving!...:mad:
17 years 5 months ago #6428 by hicrop10
Replied by hicrop10 on topic cat 10 master pins
You should have a hyd. pin press.You can also try some heat,but you will be banging with your punch and hammer till the cows come home if they are that rusted up.If you are good with the torch you can try burning them out.Good luck.
17 years 5 months ago #6471 by equipdriver
Replied by equipdriver on topic TEN rusty master pins
Sometimes if you keep applying the rust oil on the pins and pull the tractor around it might help to work the pin.
Karl
Time to create page: 0.128 seconds
