Pv 15
17 years 5 months ago #6341 by Firecat
Pv 15 was created by Firecat
Has anyone had success repairing or trying to repair a flathead carb. that has been broken off at the flange that bolts on the block. I understand that is a weak spot on the pot metal carbs. Frank
17 years 5 months ago #6349 by Walt66A
Replied by Walt66A on topic Pv 15
I have seen a lot of them that have been welded together. You might want to find some shop that has a lot of experience working with aluminum, as the process is about the same. Good luck, as those are a hard carb to find!
17 years 5 months ago #6350 by ol Grump
Replied by ol Grump on topic Pv 15
Actually, that's not aluminum, it's an aluminum alloy called pot metal. I've tried straight heli arc with aluminum filler rod and had mixed results. The best bet would be to use pot metal filler rod. If you can find an older welding shop that's been in business a long time, the ought to be able to take care of that.
17 years 5 months ago #6377 by Firecat
Replied by Firecat on topic Pv 15
Walt and Ol Grump, Thanks for the info. I forgot to mention that I don't have the broken pieces of flange from the carb. I'm going to have to find some kind of carb. that has a flange that will fit the CAT 10 and 15 block. Frank
Time to create page: 0.127 seconds
