CAT D-4 Buried!
CAT D-4 Buried!
Thank you received: 815
17 years 5 months ago #6309
That would be the early one. I suppose if you had arms like an octopus you might be able to blind adjust from above.
On the picture....put your cursor on the picture and click on the plus sign magnifier and it should come in clear as a bell.
17 years 5 months ago #6311
by tinytec
OM, Too bad about it being the early one. The photo detail is still broken up when using the "+" magnifier.
Thanks again!
Fred
17 years 5 months ago #6312
Hmmm......works fine when I open it and magnify.......anybody else having the same problem:confused:
17 years 5 months ago #6313
by tinytec
OM - I tried looking at and printing the photo with Paint Shop Pro 7, and also MS Image Composer - had the same results with both.
Fred
Thank you received: 10
17 years 5 months ago #6315
by ccjersey
I read it fine at 125%.
What it says is
Remove the cover
disengage the clutch
Put the transmission in neutral.
rotate the clutch until you can loosen the clamp nut (number 2)
put transmission in gear to stop the clutch turning and then loosen the nut.
turn the adjusting collar (number 1) clockwise to tighten the clutch.
Test the engagement by snapping the clutch in.
retighten the clamp bolt
Replace the cover.
well it says almost the same thing, it just sounds better than my way, really!
Thank you received: 5
17 years 5 months ago #6316
by catskinner
I always click in the upper left hand corner and when the Blue icon shows up, like when you are saving the pic., then move your cursor down to the lower right hand corner of the pic. and click several times. A Icon will come up and click on that and it will enlarge the pic. I don't unerstand what you guys are talking about clicking on to enlarge the pic. Where is this ? catskinner
17 years 5 months ago #6317
by tinytec
ccjersey: Thanks for the translation! I printed it out to use tomorrow morning.
It's odd that my system won't display a legible image. I even tried a second monitor. Using Windows XP with a 2000 Gateway.
OM, thanks again for the image.
Fred
17 years 5 months ago #6318
Hi catskinner,
I'm the last guy to be explaining this stuff......it's all magic to me and if it weren't for help from the young uns (now 25+) I would be totally lost.
Here goes:
When your cleared to read or post ya click on the thumbnail pic once and it shows the picture (fuzzy) with the cursor on the picture and slight movement a little circle with a plus sign in it shows to tell you the picture is capable of being magnified I guess. Click again and the picture automatically enlarges to max size.
Been doing it this way for years but I suppose there is a way to post at full size without having to go the picture web hosting route like with photobucket or imageshack. This is the first time I am aware of folks having problems viewing images???
17 years 5 months ago #6319
by ccjersey
In the bottom right corner of the Internet Explorer screen, there is a box with a magnifying glass and the magnification beside it. It's normally at 100%, but you can punch it up to 125 or 150%. Amazingly it usually improves legibility of text with magnification.
I just tried the OM way, and that's even easier than punching up the whole screen to 150%. I think the whole screen thing will even work on pictures that cannot be magnified the other way though.
17 years 5 months ago #6320
by Manx Kat
Is there not a real tractor in your state to pull this kitten out with? Around here a 444 is just a toy. A D 4 is not very big it would only take a 100 or so HP to pull it out if it had a bit of traction.
D.K. in S.K.
CAT D-4 Buried!
