Dad's old D 2 came back to life
17 years 5 months ago #6198
by Volt meter
Dad bought a used 5 U series D 2 in about 1959 or 1960 and it has been on the farm ever since. The Cat was equipped with a Holt straight blade, which was common on small farm crawler in western Oregon. In the last 10 years or so the D 2 hasn't been used much, and it hasn't even been started in the last 4 and a half years.
Dad passed away last July. My brother and I thought we would get the old Cat running and do some work around the place with it. The pony motor would start easy and run good, but the diesel engine would only hit on one cylinder. I took the cover plate off the injector pump to be sure the pumps were not sticking and that the governor linkage was working. Then I bled the tower and injector lines. I did get a little air out of one or two of the injector lines. Then, last Feb. my brother was helping me and we got the diesel engine running, and it sounded good. The steering clutches seemed to work fine, so we began servicing the old Cat to get it ready to do a little work.
We had some fir trees that blew down in a wind storm last Dec. that we wanted to salvage for logs, so the first job for the Cat was a small logging project. I haven't posted any photos on the new bulletin board, but I will try to post a few pictures of the old D 2 working.
Thank you received: 815
17 years 5 months ago #6199
Those are some great pictures......and the Cat a tribute to your Dad. Those scenes are timeless. Thanks for posting.
17 years 5 months ago #6205
by gwhdiesel75
That little D2 sure can move those logs. Wonderful to see it active and healthy like a little tractor should be. Back East, where the stands of timber grow close (unlike here in the more open forests of the Rockies), D2s were used for logging because they could get between the old-growth trees. I understand that in the west larger tractors were often used. GWH
17 years 5 months ago #6207
by Volt meter
David,
Yes, the crawler has a PTO shaft. It was equipped for a farm crawler, not a logging Cat. We have about 25 ac. of timber on our farm. When dad first bought the D 2, we used it both for field work and blade work, cleaning fence rows, etc. and for thinning the timber. Now it is mostly used for blade work.
17 years 5 months ago #6208
by Volt meter
GWH
You are right, most of the logging crawlers out here are big. Our D 2 is just a farm crawler and is not armoured for logging, and doesn't have a winch. We just have to be careful not to get brush and limbs around the engine, and be pull logs from the drawbar. We cut shorter logs in thinning our stand of timber and the little Cat does OK. The pictures were all taken the last of March and first week in April this year. Here is another pictue of about all the log the little Cat could pull - this log was about 3 and a half feet on the butt and 17' long.
17 years 5 months ago #6214
by MARTYN WILLIAMS
Great pictures and must be great memories for you captured on film.
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 5 months ago #6221
by Delta Dirt
Great set of pictures
and looks like an extremely well cared for D2.
Real interesting to see the little D2 performing those "mansize" jobs working in the woods
my parts tractor (1956 model) was a logging tractor out of south Mississippi. Don't believe it was cared for quite like your's has been.
You boys continue the care----looks like its got alot of life left in it. Bet there's an old man upstairs that's smiling all over.
Good luck!!!
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
17 years 5 months ago #6226
by Eric Egland
VM, looks like there is plenty of fire left in the Cat. That last pix looks like a full load pull. I'm thinking there must be a way to use that PTO to run a logging arch winch. Good going!!
Time to create page: 0.270 seconds
