Rust in Injection Pump
17 years 7 months ago #5902 by drujinin
HELP!!
I carefully removed the fuel filters on the D2 I hauled home a couple of weeks ago only to find lots of rust and water. At least 10 years ago, it seems the injection system was drained down but not refilled with anything.
I carefully cleaned everything except for the passage down to the injector rail gallery. How can I backflush that line/passage? What are the other tubes and passageways from the top of the fuel filter tower for or where do they lead? Any help in cleaning the rust out now before the engine is turned over to prevent the injection pumps from being damaged would be appreciated!
17 years 7 months ago #5903 by Old Magnet
Replied by Old Magnet on topic Rust in Injection Pump
Here's a couple of cross sections to help you out. The injector fuel manifold is a blind passage and best access would be by removing one or all the injector pumps which you should do anyway in your search for rust. The illustrations are from the D6 but the configuration is the same as the D2. You might also consider pulling the injection pump housing and replacing the "O" ring seal between the housing and filter tower as well as cleaning out the passages.
17 years 7 months ago #5911 by drujinin
Replied by drujinin on topic Thanks!
I'll read this on the way home and if it doesn't rain???
I'll see what else I can tear apart!
Time to create page: 0.127 seconds
